Similar to Reflect back to the client their IP address, we have a use case where we need to be able to see specific attributes of the incoming request.
Mainly: the request body. Some of our customers use a proxy in front of our service and we sometimes need to diagnose whether their proxy is inappropriately modifying incoming requests to Discourse.
The below function reflects back to the client the body their originally submitted, then we can check that for mangling:
showrequest = function(applet)
local content_type
if applet.headers["content-type"] then
content_type = applet.headers["content-type"][0]
else
content_type = ""
end
local content_length
if applet.headers["content-length"] then
content_length = applet.headers["content-length"][0]
else
content_length = ""
end
local method
method = applet.method
local body
body = applet.c:base64(applet:receive(4096))
applet:set_status(200)
applet:add_header("cache-control", "none")
applet:add_header("content-type", "application/json")
applet:start_response()
template = [[{"method":"%s","content-type":"%s","content-length":"%s","body":"%s"}]]
applet:send(
string.format(
template,
method,
content_type,
content_length,
body
end
core.register_service("showrequest", "http", showrequest)
(also demonstrated here: use of the base64 converter which I hadn’t found an example of before)
Example:
○ → curl -s https://some.host/path_to_this_lua_script -X FROB -H 'content-type: application/json' -d "$(jo foo=bar baz=quux)"
{"method":"FROB","content-type":"application/json","content-length":"26","body":"eyJmb28iOiJiYXIiLCJiYXoiOiJxdXV4In0="}
