I want to get all http request headers and values in lua context.
But I find that there is no connection header and HaProxy skips to save the connection header.
Is there a way to get all intact http request headers and values? -
haproxy version: 2.4.1
haproxy.conf
user test_user
group test_user
log /dev/log local0 debug
lua-load /path/check_http_hdr.lua
balance random
frontend nid.naver.com
default_backend backend_servers
http-request lua.check_http_hdr
default_backend back-server
backend back-server
server localhost-1 127.0.0.1:8001
- check_http_hdr.lua
core.register_action("check_http_hdr", { "http-req" }, function(txn)
txn:log(core.info, "hdr: " .. txn.f:req_hdr_names(","))
txn:log(core.info, "hdr: " .. txn.f:req_hdr("connection"))
end)
Step 1
- connect to the HaProxy with browser.
I test the chrome browser, and the browser sends the connection header.
Step 2
- check the HaProxy error log
- There is no “Connection” http request header, and lua code makes error, when it accesses to the connection header.
hdr: host,pragma,cache-control,referer,accept-encoding,accept-language,cookie
[ALERT] (21765) : Lua function 'check_http_hdr': [state-id 0] runtime error: ...path/check_http_hdr.lua:2: attempt to concatenate a nil value from ...path/check_http_hdr.lua:2: in function line 1.
- src/h1.c (haproxy source code internal)
304 int h1_headers_to_hdr_list(char *start, const char *stop,
305 struct http_hdr *hdr, unsigned int hdr_num,
306 struct h1m *h1m, union h1_sl *slp)
861 else if (isteqi(n, ist("connection"))) {
862 h1_parse_connection_header(h1m, &v);
863 if (!v.len) {
864 /* skip it */ // I find this line.
// haproxy skips to save the connection header
865 break;
866 }
867 }
