I took reference from ocserv guide:
to use SNI to split traffic to my ocserv vpn and other services (http).
Here is my configuration file:
frontend ft_ssl_vip
bind *:8443
mode tcptcp-request inspect-delay 5s tcp-request content accept if { req_ssl_hello_type 1 } default_backend bk_ssl_defaultbackend bk_ssl_default
mode tcpacl vpn-app req_ssl_sni -i vpn.example.com acl trans-app req_ssl_sni -i trans.example.com acl nc-app req_ssl_sni -i nc.example.com use-server server-vpn if vpn-app use-server server-trans if trans-app use-server server-nc if nc-app use-server server-vpn if !vpn-app !trans-app !nc-app option ssl-hello-chk server server-vpn 127.0.0.1:443 send-proxy-v2 server server-nc localhost:8888 check server server-trans localhost:9091 check
However, in haproxy.log, I can see both server-nc and server-trans fails.
Aug 11 17:12:33 localhost haproxy[19960]: Server bk_ssl_default/server-nc is DOWN, reason: Layer6 invalid response, check duration: 0ms. 2 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
Aug 11 17:12:34 localhost haproxy[19961]: Server bk_ssl_default/server-trans is DOWN, reason: Layer6 invalid response, check duration: 0ms. 1 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
Can above approach work in my case of sharing http & ocserv? if yes, how?
