Hello All,
I fight with this problem for some time now but unable to figure it out.
I tested HProxy SSL Passthrough with simple configuration using listen directive
Here is working sample:
Now I would like to use SNI to have option to route ssl traffic to multiple backends. First step was to move this configuration to frontend and backend directives:
So just to confirm: the former config with “listen my_listener” works find, but the frontend/backend configuration does not?
Are you sure that is the one and only change and it’s exactly like you posted above? I don’t see anything wrong with the new configuration and I find it hard to believe that this change is causing an issue, as haproxy does not know anything about that.
Going back to the listener config restores the service again?
This thread seems to be a little older but I’m kinda in the same boat.
The idea is to have haproxy in front of a Codeready Containers OpenShift cluster but also send requests to some locally running stuff.
The working configuration for just CrC:
maxconn 100
timeout client 500s
timeout server 500s
listen apps
bind 0.0.0.0:80
server crcvm 192.168.130.11:80 check
listen apps_ssl
bind 0.0.0.0:443
server crcvm 192.168.130.11:443 check
listen api
bind 0.0.0.0:6443
server crcvm 192.168.130.11:6443 check
With that everything is working as expected but obviously I can’t nicely forward to other services so I tried the following:
frontend http
bind 0.0.0.0:80
acl openshift hdr_end(host) -i apps-crc.testing
use_backend openshift if openshift
frontend https
bind 0.0.0.0:443
acl openshift-ssl hdr_end(host) -i apps-crc.testing
acl promlens hdr(host) -i promlens.rackow.io
acl prometheus hdr(host) -i prometheus.rackow.io
acl grafana hdr(host) -i grafana.rackow.io
use_backend openshift-ssl if openshift-ssl
use_backend promlens if promlens
use_backend prometheus if prometheus
use_backend prometheus if grafana
frontend openshift-api
bind 0.0.0.0:6443
acl openshift-api hdr_end(host) -i crc.testing
use_backend openshift-api if openshift-api
backend openshift
backend promlens
server docker 127.0.0.1:8080 check
backend prometheus
server docker 127.0.0.1:9090 check
backend grafana
server docker 127.0.0.1:3000 check
but when doing that something seems to go wrong.
In the logs I get:
