SSL Pass-through yields SSL errors
Hi there.
I’m almost at the end of my tether here. I have no idea why this doesn’t work.
All I am trying to do is SSL passthrough which should be simple enough (or so I thought) but 99% of the time I am getting some unknown SSL error
root@kuroko:~# curl -k https://corihaws.co.uk
curl: (35) Unknown SSL protocol error in connection to corihaws.co.uk:443
I note this error does not occur if I set the default backend - so the issue must be with the rule but I’m clearly not understanding it.
Here is my config
        log /dev/log    local0
        log /dev/log    local1 notice
        log     global
        mode    http
        #option httplog
        option  dontlognull
        timeout connect 50000
        timeout client  50000
        timeout server  50000
# Frontend: fe-http ()
frontend fe-http
    stats uri /haproxy?stats
    # tuning options
    # logging options
    # ACL: corihaws
    acl acl_corihaws hdr_end(host) -i corihaws.co.uk
    # ACTION: misaka00002-http
    use_backend be-misaka00002-http if acl_corihaws
# Frontend: fe-https ()
frontend fe-https
    bind *:443
    # tuning options
    # logging options
    # ACL: corihaws-ssl
    acl acl_corihaws-ssl req.ssl_sni -m end -i corihaws.co.uk
    # ACTION: misaka00002-https
    use_backend be-misaka00002-https if acl_corihaws-ssl
   # default_backend be-misaka00002-https
# Backend: be-misaka00002-http ()
    balance source
    # stickiness
    stick on src
    # tuning options
    http-reuse never
    server misaka00002-http 10.0.1.102:80
# Backend: be-misaka00002-https ()
    balance source
    # stickiness
    #stick-table type ip size 50k expire 30m
    #stick on src
    # tuning options
    server misaka00002-https 10.0.1.102:443
Any help would be much appreciated.
Kind Regards
Cori
As per the documentation:
https://cbonte.github.io/haproxy-dconv/1.9/configuration.html#7.3.5-req.ssl_sni
You need to wait for the complete client_hello, before matching the SNI value:
# Wait for a client hello for at most 5 seconds
# ACL: corihaws-ssl
Hi, Thanks for the response.
This seems to have been the problem.
I will admit, I was having this issue using the OPNSense haproxy plugin, so I setup a separate server running haproxy and copied over the essential config options to diagnose the issue. Evidently, for whatever reason OPNsense is not auto-generating the required client_hello config options…
Many Thanks
Cori
