SSL passthrough conditions not working, everything sent to default_backend
Hello, I’m brand new to HAProxy. I’m running it on ProxMox attempting to have it be the ‘traffic control’ for the other services on my Proxmox server. My SSL passthrough is not working at all. Everything SSL is sent to default_backend. non-SSL traffic seems fine. I’d rather let the backend servers handle the certs instead of having HAProxy terminate SSL, as some of the backend services insist on communicating via https only. I’ll post my config here.
        log /dev/log    local0
        log /dev/log    local1 notice
        #  See: https://ssl-config.mozilla.org/#server=haproxy&server-version=2.0.3&config=intermediate
        log     global
        mode    http
        option  httplog
        option  dontlognull
        timeout client  50000
        timeout server  50000
### http ###
frontend http
        bind :80
        use_backend backend_one_http if { hdr(host) -i sub1.server1.com }
        use_backend backend_two_http if { hdr(host) -i server1.com }
        use_backend backend_two_http if { hdr(host) -i server2.com }
		default_backend backend_two_http
        server backend_one 10.0.0.10:80 check
        server backend_two 10.0.0.20:80 check
### https ###
frontend https
        bind :443
        use_backend backend_one_https if { req.ssl_sni -i sub1.server1.com }
        use_backend backend_two_https if { req.ssl_sni -i server1.com }
        use_backend backend_two_https if { req.ssl_sni -i server2.com }
		default_backend backend_two_https
        option ssl-hello-chk
        server backend_one 10.0.0.10:443 check
        server backend_two 10.0.0.20:443 check
All SSL traffic is being sent to the default_backend instead of where it should be going via the use_backend conditions. Is there something obvious I’m missing here?
Here is my haproxy -vv output:
root@proxy:~# haproxy -vv
HAProxy version 2.4.7-1ppa1~focal 2021/10/07 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.4.7.html
Running on: Linux 5.11.22-5-pve #1 SMP PVE 5.11.22-10 (Tue, 28 Sep 2021 08:15:41 +0200) x86_64
  TARGET  = linux-glibc
  CPU     = generic
  CC      = cc
  CFLAGS  = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-s1iGIG/haproxy-2.4.7=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
  DEBUG   =
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -CLOSEFROM -ZLIB +SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL -PROCCTL +THREAD_DUMP -EVPORTS -OT -QUIC +PROMEX -MEMORY_PROFILING
Built with gcc compiler version 9.3.0
              h2 : mode=HTTP       side=FE|BE     mux=H2       flags=HTX|CLEAN_ABRT|HOL_RISK|NO_UPG
            fcgi : mode=HTTP       side=BE        mux=FCGI     flags=HTX|HOL_RISK|NO_UPG
       <default> : mode=HTTP       side=FE|BE     mux=H1       flags=HTX
              h1 : mode=HTTP       side=FE|BE     mux=H1       flags=HTX|NO_UPG
       <default> : mode=TCP        side=FE|BE     mux=PASS     flags=
            none : mode=TCP        side=FE|BE     mux=PASS     flags=NO_UPG
        [FCGI] fcgi-app
Before matching SNI values in the buffer with req.ssl_sni, you need to wait for the buffer to actually be filled with that data:
# Wait for a client hello for at most 5 seconds
https://cbonte.github.io/haproxy-dconv/2.2/configuration.html#7.3.5-req.ssl_sni
Thank you!
