I’m using haproxy as an SSL terminator and SNI based service selector for my family server. Some of the subdomains use client side certificate, some of them not. Some of them are TCP, others are HTTP. For me haproxy is a convenient solution for SSL termination, authentication and even HTTP/2 support for my dummy embedded servers, alarm system, openvpn (over tls) and nextcloud instance. (A lot of things, except load balancing
My problem with switching subdomain in a browser from an unauthenticated section to a restricted section. I use Let’s encrypt wildcard certificate for my domain, so the browser would like to use the same ssl session with the same SNI for all the subdomains. Only the HTTPS services are affected, so I can check the HOST field in the HTTP header. Now I know, that the browser want to reach a restricted subdomain and drop and error message. The only way to reach the restricted subdomain is to restart the browser.
Is it possible to close the SSL session (see close-session-backend in my config) to force the browser for a new SSL negotiation (with client certificate)? I don’t want to use the verify optional solution at bind, as I don’t want the browser to popup a window for client side certificate where I don’t need it. After all when I don’t give a certificate there, I don’t think it will prompt again when I switch subdomains.
I was thinking about using SNIs in the crt-list.txt, but I don’t think it would work, as the same wildcard certificate will be used for every line and the browser will know nothing about this trick. Will haproxy handle these lines in the crt-list.txt as different ssl sessions?
I don’t want to use two or more certificates if possible, wildcard is a very flexible solution for me.
Thank you for your help!
ssl-default-bind-options prefer-client-ciphers no-sslv3 no-tlsv10 no-tlsv11 no-tls-tickets
maxconn 2048
option logasap
timeout connect 10000
timeout client 300000
timeout server 300000
source 0.0.0.0 usesrc clientip
# http -> https redirection
frontend http-frontend
bind 192.168.10.52:80
# Switch between subdomains by sni
frontend mode-switch
# option tcplog
bind 192.168.10.52:443
use_backend verif-none-tcp if { req.ssl_sni -i ovpn.mydomain.com }
use_backend verif-required-tcp if { req.ssl_sni -i tcpservice1.mydomain.com }
use_backend verif-none-error if !{ req.ssl_sni -m dom mydomain.com }
use_backend verif-none if { req.ssl_sni -i mydomain.com } || { req.ssl_sni -i www.mydomain.com } || { req.ssl_sni -i other.mydomain.com }
default_backend verif-required
backend verif-none
server recir abns@haproxy-normal send-proxy-v2
server recir abns@haproxy-clientcert send-proxy-v2
server recir abns@haproxy-tcp-normal send-proxy-v2
server recir abns@haproxy-tcp-clientcert send-proxy-v2
server recir abns@haproxy-error send-proxy-v2
# HTTPS subdomains without client cert.
# https://mydomain.com
# https://www.mydomain.com
# https://other.mydomain.com
frontend fe-ssl-normal
bind abns@haproxy-normal accept-proxy ssl crt-list /etc/haproxy/certs/crt-list.txt alpn h2,http/1.1 no-tls-tickets strict-sni
use_backend https-backend if { hdr(host) -i mydomain.com } || { hdr(host) -i www.mydomain.com } || { hdr(host) -i other.mydomain.com }
# Wants to reach a restricted subdomain with wrong SNI
default_backend close-session-backend
http-response set-header Strict-Transport-Security "max-age=15552000; includeSubDomains"
server apache2-https 192.168.10.52:81
# HTTPS subdomains with client cert.
# https://*.mydomain.com
frontend fe-ssl-clientcert
bind abns@haproxy-clientcert accept-proxy ssl crt-list /etc/haproxy/certs/crt-list.txt ca-file /etc/haproxy/certs/https_client_certs/ca.crt verify required crl-file /etc/haproxy/certs/https_client_certs/root_crl.pem alpn h2,http/1.1 no-tls-tickets strict-sni
use_backend alarm-backend if { ssl_fc_sni -i alarm.mydomain.com } { ssl_c_s_dn(CN) -m reg ^(user1|user2)$ }
use_backend gitlist-backend if { ssl_fc_sni -i gitlist.mydomain.com } { ssl_c_s_dn(CN) -m reg ^(user1)$ }
default_backend access-denied-backend
source 192.168.10.52
server alarm-http 192.168.10.51:8000
# TLS / TCP subdomains without client cert.
# https://ovpn.mydomain.com -- OpenVPN
frontend fe-ssl-tcp-normal
bind abns@haproxy-tcp-normal accept-proxy ssl crt-list /etc/haproxy/certs/crt-list.txt
use_backend ovpn-backend if { ssl_fc_sni -i ovpn.mydomain.com }
server ovpn 192.168.10.52:1122
# TLS / TCP subdomains with client cert.
# https://tcpservice1.mydomain.com
frontend fe-ssl-tcp-clientcert
bind abns@haproxy-tcp-clientcert accept-proxy ssl crt-list /etc/haproxy/certs/crt-list.txt ca-file /etc/haproxy/certs/https_client_certs/ca.crt verify required crl-file /etc/haproxy/certs/https_client_certs/root_crl.pem
use_backend tcpservice1-backend if { ssl_fc_sni -i tcpservice1.mydomain.com } { ssl_c_s_dn(CN) -m reg ^(user1|user2|user3|user4)$ }
server tcpservice1 192.168.10.52:54321
# Error backends
frontend fe-ssl-error
bind abns@haproxy-error accept-proxy ssl crt-list /etc/haproxy/certs/crt-list.txt alpn h2,http/1.1
use_backend error-backend
errorfile 503 /etc/haproxy/err_access_denied.http
errorfile 503 /etc/haproxy/err_no_sni.http
# option forceclose
# http-request redirect code 301 location https://%[hdr(host)]%[capture.req.uri]
