Hi. I’m trying forward response from outside service to internal server. I’m using haProxy for this issue. But i don’t know, what i’m doing bad. Response going to public endpoint in DMZ and i need to forward it to internal server.
Here’s my config:
frontend api-in-80
acl api_callback_host hdr(host) -i public.endopoint.com
use_backend cb-api if api_callback_host
default_backend api-servers-def
stats uri /haproxy?stats
stats realm API-Proxy\Stats
option httpclose
server api-web-def 127.0.0.1:8066 check maxconn 6
backend cb-api
option httpclose
option httpchk get /api/v1/test
server cb-api 10.x.x.x:1234 check maxconn 9
Thanks for your help/
