I’m working with HAProxy in Docker. I’m trying to set up HAProxy so that whatever the requested port is will be forwarded to the backend.
frontend main
bind *:8091-8096
bind *:11200-11211
bind *:18091-18096
bind *:9102
acl is_couchbase hdr(host) -i couchbase.local
use_backend couchbase_server if is_couchbase
frontend main_http
bind *:15672
acl is_rabbit hdr(host) -i rabbit.local
use_backend rabbit_server if is_rabbit
server couchbase couchbase-server
server rabbit rabbit
For example, I should be able to make a request to rabbit.local:15672 and get routed there. When I try to do this though, I’m just getting 503’s.
If I modify my config to be:
server rabbit rabbit:15672
Now I can go to rabbit.local and it works.
Reading around here, I get the impression that my original config should be working, but it’s not.
Any ideas?
