Hi Guys
I have some problems getting geoip working correctly - I’m using the “recipe” from https://github.com/superstes/haproxy-geoip, but it doesn’t seem to work… no blocking and no mapping in file, and no obvious errors in logfiles
I have have Python Backend running in systemd, and from my point of view that part works:
I have the following files:
ls -lh /opt/haproxy/
total 8.0K
-rwxr-xr-x 1 haproxy haproxy 2.9K Jun 21 01:20 geoip_lookup.py
-rwxr-xr-x 1 root root 1.4K Jun 21 00:21 geoip_lookup_w_backend.lua
ls -lh /var/geoip/
total 6.3M
-rw-r–r-- 1 haproxy haproxy 6.3M Jun 18 14:01 GeoLite2-Country.mmdb
-rw-r–r-- 1 haproxy haproxy 0 Jun 21 00:40 haproxy_geoip_country.map
And I have installed maxminddb python module:
python3 -m pip install maxminddb
And the relevant part of haproxy.cfg:
log 127.0.0.1 local0
maxconn 6000
uid 99
gid 99
ssl-default-server-options force-tlsv12 no-tls-tickets
ssl-default-server-ciphers ECDH+AESGCM:ECDH+CHACHA20:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA+AESGCM:RSA+AES:!aNULL:!MD5:!DSS
ssl-default-bind-options force-tlsv12 no-tls-tickets
ssl-default-bind-ciphers ECDH+AESGCM:ECDH+CHACHA20:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:DH+AES:RSA+AESGCM:RSA+AES:!aNULL:!MD5:!DSS
lua-load /opt/haproxy/geoip_lookup_w_backend.lua
log stdout format raw local0
_
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
_
frontend http
bind :80
_
frontend http-SSL
bind :443 ssl crt
option httpclose
acl private_nets src 192.168.0.0/16 172.16.0.0/12 10.0.0.0/8 127.0.0.0/8 ::1
http-request set-var(txn.geoip_country) str(00) if private_nets
acl geoip_country_in_map src,ipmask(24,48),map_ip(/var/geoip/haproxy_geoip_country.map) -m found
http-request set-var(txn.geoip_country) src,ipmask(24,48),map(/var/geoip/haproxy_geoip_country.map) if !private_nets geoip_country_in_map
http-request lua.lookup_geoip_country if !{ var(txn.geoip_country) -m found }
http-request capture var(txn.geoip_country) len 2
http-request set-map(/var/geoip/haproxy_geoip_country.map) %[src,ipmask(24,48)] %[var(txn.geoip_country)] if !private_nets !geoip_country_in_map
acl block_country src,map_ip(/var/geoip/haproxy_geoip_country.map) -m sub ru
acl block_country src,map_ip(/var/geoip/haproxy_geoip_country.map) -m sub cn
http-request deny deny_status 403 if block_country
The Haproxy version:
haproxy -v
HAProxy version 2.8.10-f28885f 2024/06/14 - https://haproxy.org/
Status: long-term supported branch - will stop receiving fixes around Q2 2028.
Known bugs: http://www.haproxy.org/bugs/bugs-2.8.10.html
Running on: Linux 4.12.14-150.47-default #1 SMP Wed Dec 18 15:05:52 UTC 2019 (8162e25) x86_64
Make settings:
make -j $(nproc) TARGET=linux-glibc USE_OPENSSL=1 USE_LUA=1 USE_PCRE2=1 USE_SYSTEMD=1
Hope there’s somebody out there with a grand idea ![]()
Best regards
/Flemming
