Goal: to use HAProxy to provide port multiplexing including for SSH.
Eventually, HAProxy will need to pass http/https 80/443 to nginx and I’ve gotten that to at least connect to the service it was supposed to.
I installed HAProxy 2.9.9 from the Ubuntu Oracular repo to get all the repo-packaged stuff like systemd files, logging, etc.
I compiled and installed HAProxy version 3.0.4-6cae9b-53 2024/09/10 on top of that.
With respect to SSH, I am following Route SSH Connections with HAProxy (In-Depth Configuration) but I cannot get it to work. Part of the problem is that I only have one backend SSH server so it doesn’t apply perfectly.
$ sshd --version
unknown option -- -
OpenSSH_9.7p1 Ubuntu-7ubuntu3, OpenSSL 3.3.1 4 Jun 2024
$ cat /etc/haproxy/haproxy.conf
log /dev/log local0 info
# mode tcp
# option tcplog
errorfile 400 /var/log/haproxy/errors/400.http
errorfile 403 /var/log/haproxy/errors/403.http
errorfile 408 /var/log/haproxy/errors/408.http
errorfile 500 /var/log/haproxy/errors/500.http
errorfile 502 /var/log/haproxy/errors/502.http
errorfile 503 /var/log/haproxy/errors/503.http
errorfile 504 /var/log/haproxy/errors/504.http
frontend fe_ssh
bind *:2222 ssl crt /etc/haproxy/certs/mydomainname.com.pem
# bind *:2222 ssl crt /etc/haproxy/certs/ssl.pem #created self-signed 2024.09.19
log-format "%ci:%cp [%t] %ft %b/%s %Tw/%Tc/%Tt %B %ts %ac/%fc/%bc/%sc/%rc %sq/%bq dst:%[var(sess.dst)] "
tcp-request content set-var(sess.dst) ssl_fc_sni
# use_backend %[ssl_fc_sni] #no connection to haproxy.
use_backend ssh_backend
backend ssh_backend
# server ssh1 127.0.0.1:22 check
# server ssh1 127.0.0.1:22 check ssl verify none # error: "haproxy[165452]: backend ssh_backend has no server available!"
server ssh1 127.0.0.1:22 ssl verify none
so now when I try to connect to this using something like what the blog example:
ssh -o ProxyCommand="openssl s_client -quiet -connect ssh.mydomainname.com:2222 -servername ssh1" ssh
Connecting to 11.22.33.44
depth=2 C=US, O=Internet Security Research Group, CN=ISRG Root X1
verify return:1
depth=1 C=US, O=Let's Encrypt, CN=E5
verify return:1
depth=0 CN=mydomainname.com
verify return:1
Connection closed by UNKNOWN port 65535
systemctl/sshd reports this:
Sep 12 16:54:48 server sshd[165969]: banner exchange: Connection from 127.0.0.1 port 39668: invalid format
haproxy.log
2024-09-12T16:54:48.990339-04:00 server haproxy[165917]: 192.168.1.1:59638 [12/Sep/2024:16:54:45.933] fe_ssh~ ssh_backend/ssh1 5/-1/3056 0 SC 1/1/0/0/3 0/0 dst:ssh1
I’m at a loss here to figure out what the blog makes it appear to be simple.
Guidance is appreciated.
