HA Proxy - Gracefully close connections on servers
We are running into a snag in our deployment process. While removing servers from rotation, persistent connections are dropped. We are currently using cookie based persistence. We’d like the connections to gracefully move to another server, instead of being dropped.
Here is what we are doing to remove a server from rotation:
  1. Change the state of the server to DRAIN (via socat command). This command disallows any new connections to be on the server, however persistent connections are still hitting our server.
  2. Change “health.html” contents to “DOWN”. This marks the server as “DOWN”, but all connections are dropped and users bounced to another server.
We are unable to determine the step we are missing between #1 & #2. We have tried the following:
  • Incorporating the “MAINT” status
  • Setting the maxconn value on a server to -1
  • Renaming the “health.html” file instead of changing the contents. This causes the server to be marked as “NOLB”
Does anyone have any suggestions?
Below is the HA Proxy config:
        maxconn 30000
        log /dev/log    local0
        log /dev/log    local1 notice
        nbthread 48
        tune.bufsize 32768
        tune.ssl.cachesize 30000
        tune.ssl.lifetime  600
        stats socket ipv4@127.0.0.1:9999 level admin
            log     global
            mode    http
            option  httplog
            option  dontlognull
            timeout connect 121000
            timeout client  121000
            timeout server  121000
    frontend fe_main
            bind :80
            bind :443 ssl crt /etc/cc-ssl/[redacted].pem crt /etc/cc-ssl/[redacted].pem
            default_backend be-https
    frontend stats
            bind *:8404
            stats uri /stats
    backend be-https
            cookie NUMID insert indirect nocache
            option httpchk GET /health.html HTTP/1.1\r\nHost:\ www
            http-check disable-on-404
            http-check expect string UP
            default-server inter 3s fall 2 rise 2 slowstart 5m
            server s1 10.10.10.1:443 ssl verify none check cookie 1
            server s2 10.10.10.2:443 ssl verify none check cookie 2
            server s3 10.10.10.3:443 ssl verify none check cookie 3
            server s4 10.10.10.4:443 ssl verify none check cookie 4
haproxy -vv output:
HA-Proxy version 2.0.10-1ppa1~bionic 2019/11/26 - https://haproxy.org/
  TARGET  = linux-glibc
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-M3LRQ8/haproxy-2.0.10=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-format-truncation -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-old-style-declaration -Wno-ignored-qualifiers -Wno-clobbered -Wno-missing-field-initializers -Wno-implicit-fallthrough -Wno-stringop-overflow -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
Built with OpenSSL version : OpenSSL 1.1.1  11 Sep 2018
Running on OpenSSL version : OpenSSL 1.1.1  11 Sep 2018
Built with PCRE2 version : 10.31 2018-02-12
Available services :
        prometheus-exporter
Try adding ‘option redispatch’ to the backend.
We (I’m his teammate) tried adding ‘option redispatch’ to the backend but that didn’t seem to make an impact.
Do you think we need to add ‘option http-server-close’ ?
