Hi Guys,
I have a java web app running behind HAProxy Load balancer, users getting authentication error when connecting (they can’t login), but everything is working fine with incognito mode or if clear browser cache.
This is looks like a sticky session issue. we are running haproxy 2.3 and client requests will be redirected by haproxy using round-robin (our webapp required to have persistent connections) so here is my config. appreciate any feedback. cheers
log stdout format raw local0 info
pidfile /run/haproxy.pid
timeout connect 60000
bind *:1936
stats uri /
stats hide-version
stats auth xxx:xxx
frontend http-frontend
bind *:443 ssl crt /server.pem
default_backend http-backend
resolvers localdns
parse-resolv-conf
hold valid 5s
default-server inter 2s fastinter 2s downinter 2s fall 3 rise 2
cookie JSESSIONID prefix
dynamic-cookie-key MYKEY
cookie SRVID insert dynamic
default-server resolvers localdns
option httpchk HEAD /ha/health HTTP/1.0
server-template webapp1 1 ${BACKEND_1} check fall 3 rise 2
server-template webapp2 1 ${BACKEND_2} check fall 3 rise 2
You seem to have conflicting configuration regarding cookies, please remove:
from the configuration.
@lukastribus thanks for the help, made the change to my config with (removed cookie JSESSIONID prefix as requested)
cookie SRVID insert dynamic nocache
But users are seeing different page details each time they refresh page. but if they remove the cache, then they can see the correct page details. do i need to add any cache expiry ? (most of our users use chrome browser)
And when and how do they come in the situation?
You are saying it works if they clear the cache, please explain what happens after that. Does it work for some time and then it stops?
@lukastribus even some people having login issues as well, it worked some times but not stable. sometimes you see different pages after refreshing the page. still we are having login issues, and it worked after cleaning cache.
so i decided to try the following , please let me know your thoughts.
server-template back1 1 ${BACKEND_NODE1} check cookie back1
server-template back2 1 ${BACKEND_NODE2} check cookie back2
completely removing following and adding only, cookie JSESSIONID prefix
thanks in advance.
I don’t know the root cause of the issue. Your change means you are no longer using the dynamic cookie mode, but static configuration. If that fixes the issue great, but we don’t really understand the root cause at this point.
Can you share the complete configuration and the output of haproxy -vv?
@lukastribus here is the requested information.
Current running config (having login issues ,page refresh gives different output, clear cache solve the issue, not working in incognito mode- i think chrome will disable third party cookies in that mode so this is acceptable)
bind *:1936
stats uri /
stats hide-version
stats auth admin:admin
resolvers localdns
parse-resolv-conf
hold valid 5s
server-template node1 1 ${BACKEND_NODE1} check fall 3 rise 2
server-template node2 1 ${BACKEND_NODE2} check fall 3 rise 2
haproxy -vv
root@1b70e94b92a8:/# haproxy -vv
HA-Proxy version 2.3.4-10189c9 2021/01/13 - https://haproxy.org/
Status: stable branch - will stop receiving fixes around Q1 2022.
Known bugs: http://www.haproxy.org/bugs/bugs-2.3.4.html
Running on: Linux 5.10.76-linuxkit #1 SMP Mon Nov 8 10:21:19 UTC 2021 x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
OPTIONS = USE_PCRE2=1 USE_PCRE2_JIT=1 USE_GETADDRINFO=1 USE_OPENSSL=1 USE_LUA=1 USE_ZLIB=1
DEBUG =
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL +LUA +FUTEX +ACCEPT4 -CLOSEFROM +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL -SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with OpenSSL version : OpenSSL 1.1.1d 10 Sep 2019
Running on OpenSSL version : OpenSSL 1.1.1d 10 Sep 2019
Built with PCRE2 version : 10.32 2018-09-10
Built with gcc compiler version 8.3.0
<default> : mode=HTTP side=FE|BE mux=H1
<default> : mode=TCP side=FE|BE mux=PASS
[FCGI] fcgi-app
