Hey guys,
I’m having login issues with persistent cookies , this happens when one node of the cluster restarts and some users will not be able to login. i think its due to the restart , cookie in the client browser is no longer valid . Can this be fixed using cookie JSESSIONID prefix nocache ? or expiry ? appreciate your help.
log stdout format raw local0 info
pidfile /run/haproxy.pid
timeout connect 60000
bind *:1936
stats uri /
stats hide-version
stats auth admin:admin
frontend http-frontend
bind *:443 ssl crt /server.pem
default_backend http-backend
resolvers localdns
parse-resolv-conf
hold valid 5s
default-server inter 2s fastinter 2s downinter 2s fall 3 rise 2
default-server resolvers localdns
option httpchk HEAD /ha/health HTTP/1.0
server-template node1 1 ${BACKEND_NODE1} check cookie node1
server-template node2 1 ${BACKEND_NODE2} check cookie node2
