Hello guys,
i am using HAProxy to encrypt and load balance my two Axios Assyst Jboss webservers.
The main functions are working. HAProxy direkts with encryption to the Assyst Loginpage.
But after logging in, the page is just blank and i need to refresh the page to get Assyst fully loaded.
Page after login:
and after refresh:
I think there is an issue in directing the response from the webserver after logging in.
Does anyone had an similar experiance or idea to fix it?
Here is my config:
log 127.0.0.1 local0
chroot /var/log/haproxy
pidfile /var/run/haproxy.pid
maxconn 100000
stats socket /var/run/haproxy.sock mode 660 level admin
ca-base /etc/haproxy/cert
crt-base /etc/haproxy/cert
option accept-invalid-http-response
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 100000
stats hide-version
stats refresh 30s
stats show-node
stats auth assyst:assyst
stats uri /haproxy?stats
frontend http_https
bind :443 ssl crt /etc/haproxy/cert/serverlb01.pem crt-ignore-err all
bind :80
# option http-keep-alive
default_backend assyst_prod_lb
server server1.domain.net 101.161.219.202:8080 cookie s1 check inter 5s
server server2.domain.net 101.161.219.203:8080 cookie s2 check inter 5s
