Hello everyone .
Thank you for your wonderful work, and such a great community. this is my first time using haproxy and and trying to create a load balancer on https.
The main domain points to Haproxy and 2 subdomains point to the upload servers. www1 and www2, everything works fine in the 2 load servers with valid ssl certificates, all correct.
Only that when loading the web by Haproxy instead of loading the domain it is pointed to the server’s empty page and does not load the domain with the app from within the servers.
I’m going to upload a photo so you can see that the home page of the CWP server is loading and it does not point to the domain www1, www2.
I don’t know what was wrong in the configuration or if something is missing.
Thank you.
        ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE>
        log     global
        mode    http
        option  httplog
        option  dontlognull
        timeout client  50000
        timeout server  50000
frontend www-http
   #reqadd X-Forwarded-Proto:\ http
   default_backend www-backend
frontend www-https
    bind www.dominio.dev:443 ssl crt /etc/letsencrypt/live/vmi4455.contaboserver.net/1.pem
    stats auth  cda:cda
    http-request add-header X-Forwarded-Port 443
    http-response add-header Strict-Transport-Security max-age=15768000
  # use_backend letsencrypt-backend if letsencrypt-acl
backend www-backend
   #http-request redirect scheme https if http
   server www-1 www1.dominio.dev:443 ssl verify none
   server www-2 www2.dominio.dev:443 ssl verify none maxconn 5000
   server www-3 www3.dominio.dev:443 check
