Problem in forwarding traffic of all subdomains and domains
Hello
I would be very grateful if you could help me
I redirected a series of domains to my load balancer through my DNS server
I don’t have a problem with these settings. My problem is that I have to add the same operation one by one for each subdomain, which is too much. Is there a way to automatically do the same for all wildcards and not add each one?
timeout connect 10h
timeout client 10h
timeout server 10h
timeout http-keep-alive 1s
timeout http-request 10s
timeout queue 30s
frontend https_front
bind *:443
use_backend example.com if { req_ssl_sni -i example.com }
backend example.com
server example.com example.com:443 check
