I’ve been goggling and looking for guides and tried piecing this together with lo luck whatsoever. What I need to do is direct web traffic to different servers depending on the domain (for now)… I’m using the latest HAProxy (1.7.9 running on an Ubuntu machine (virtual) and my router directs all traffic for port 80 to it.
I’ve been following what guides I could find to the best of my understanding and I finally have the service at least start without failure, but once running it seems it completely ignores all my hostmapping and just sends everything to the default backend.
I have 3 webservers running on 3 different machines with their own static IPs (2 Apache and 1 IIS) and this is the config I’ve come up with.
maxconn 256
# My stuff
stats uri /hapstats
stats realm "HAProxy\ Statistics"
stats auth steiner:password
stats refresh 5s
frontend http-in
# Define hosts
acl host_tifozi hdr(host) -i tifozi.net
acl host_tabardinn hdr(host) -i yetabardinn.net
acl host_tacticus hdr(host) -i tacticus.org
acl host_secunet hdr(host) -i secunet.se
acl host_windhund hdr(host) -i windhund.biz
# Hostmapping
use_backend Srv_1 if host_tacticus
use_backend Srv_1 if host_windhund
use_backend Srv_2 if host_tifozi
use_backend Srv_2 if host_tabardinn
use_backend Srv_3 if host_secunet
default_backend Srv_1
backend Srv_1
option httpclose
server Apache_1 10.84.42.4:80 check
backend Srv_2
option httpclose
server Apache_2 10.84.42.15:80 check
backend Srv_3
option httpclose
server IIS_1 10.84.42.14:80 check
Please someone help me figure this out and point me in the right direction, I would be immensely grateful!
