I have a hub app routed, and sometimes it gets wrongly routed to the ssl_default backend. Leading to a 404. A control + F5 is needed to get it right, which cannot be done for resources files, like javascripts. Here is my configuration :
File: /etc/haproxy/hosts.map
hub.domain.com hub_server
File: /etc/haproxy/haproxy.cfg
option log-health-checks
timeout client 50s
timeout server 50s
frontend http-in
bind 10.0.16.10:80
http-request redirect scheme https if !{ ssl_fc }
# redirect scheme https code 301 if !{ ssl_fc }
frontend https-in
bind 10.0.16.10:443
#tcp-request content capture req.ssl_sni len 25
#log-format "%ci:%cp [%t] %ft %b/%s %Tw/%Tc/%Tt %B %ts %ac/%fc/%bc/%sc/%rc %sq/%bq ssl_fc_has_sni '%[ssl_fc_has_sni]' sni:'%[capture.req.hdr(0)]'"
use_backend %[req.ssl_sni,lower,map(/etc/haproxy/hosts.map,ssl_default)]
# default_backend ssl_default
backend ssl_default
# maximum SSL session ID length is 32 bytes.
stick-table type binary len 32 size 30k expire 30m
acl clienthello req_ssl_hello_type 1
acl serverhello rep_ssl_hello_type 2
# use tcp content accepts to detects ssl client and server hello.
tcp-request content accept if clienthello
# no timeout on response inspect delay by default.
tcp-response content accept if serverhello
stick on payload_lv(43,1) if clienthello
# Learn on response if server hello.
stick store-response payload_lv(43,1) if serverhello
option ssl-hello-chk
server nginx-local 127.0.0.1:4443 send-proxy-v2 on-marked-up shutdown-backup-sessions weight 11 check inter 1s fall 3 rise 2
server server-hub-backup 127.0.0.1:4503 send-proxy-v2 backup non-stick
backend hub_server
server server-hub1 hub.lxd:4443 send-proxy-v2 weight 11 check inter 1s fall 3 rise 2
server server-hub2 10.97.89.14:4443 send-proxy-v2 on-marked-up shutdown-backup-sessions weight 22 check inter 1s fall 3 rise 2
The certificates delivered by the backends are wildcard. For the ssl_default backend:
Common name: domain.com
SANs: *.domain.com, *.office.domain.com, domain.com
Valid from January 17, 2021 to April 17, 2021
Issuer: R3
For the hub_server backend
SANs: *.domain.com, domain.com
Valid from January 3, 2021 to April 3, 2021
Issuer: R3
