if I use haproxy 2.8, this configue is ok:
frontend tcp-in
bind *:48202
# tcp-request content accept if TRUE
tcp-request content capture payload(0,9) len 9
log-format %[capture.req.hdr(0)]
# tcp-request content accept if { payload(0,9) -m bin 474554202f766d686b302f }
# tcp-request content accept if { payload(0,8) -m bin 474554202f737461 }
# 根据检查结果将请求分配到不同的后端
# use_backend hell-backend if { payload(0,11) -m bin 474554202f766d686b302f }
use_backend hell-backend if { payload(0,8) -m bin 474554202f766d68 }
use_backend haproxy-http-backend if { payload(0,8) -m bin 474554202f737461 }
default_backend default-backend
server server1 38.207.173.10:42441 check
server default-server 127.0.0.1:38202 check
server default-server2 127.0.0.1:48200 check
in version 3.0, the log-format %[capture.req.hdr(0)] is wrong, and the log says:haproxy[95097]: [ALERT] (95097) : config : Parsing [/etc/haproxy/haproxy.cfg:46]: failed to parse log-format : logformat expression not usable here (at least one node depends on HTTP mode).
If I remove the comment sign of # tcp-request content accept if TRUE, haproxy doesn’t work.
