Ive put together a very simple configuration. I have haproxy 3.1 deployed with the following configuration:
log /dev/log local1 debug
stats socket /var/run/haproxy.sock mode 600 level admin
frontend test
bind *:443 ssl crt /etc/ssl/private/mydomain.pem
default_backend web_servers
backend web_servers
server server1 10.0.131.75:80
Super simple. And I can hit the HTTP site with zero problems. However, the TLS side is a different story. I banged out a self signed cert and pretty much just expected this to work. But on firefox I’m getting the ERR_SSL_PROTOCOL_ERROR error back. And even with debug level logging turned on, this is all I get in my logs:
2025-01-31T22:23:02.995649+00:00 ip-10-0-132-14 haproxy[22600]: [NOTICE] (22600) : Initializing new worker (22604)
2025-01-31T22:23:03.053383+00:00 ip-10-0-132-14 haproxy[22600]: [NOTICE] (22600) : Loading success.
2025-01-31T22:23:54.506079+00:00 ip-10-0-132-14 haproxy[22604]: 10.0.0.75:18632 [31/Jan/2025:22:23:54.504] test test/<NOSRV> -1/-1/-1/-1/0 400 0 - - PR-- 2/2/0/0/0 0/0 "<BADREQ>"
2025-01-31T22:23:54.506230+00:00 ip-10-0-132-14 haproxy[22604]: 10.0.0.75:18632 [31/Jan/2025:22:23:54.504] test test/<NOSRV> -1/-1/-1/-1/0 400 0 - - PR-- 2/2/0/0/0 0/0 "<BADREQ>"
2025-01-31T22:23:54.506872+00:00 ip-10-0-132-14 haproxy[22604]: 10.0.0.75:46138 [31/Jan/2025:22:23:54.505] test test/<NOSRV> -1/-1/-1/-1/0 400 0 - - PR-- 1/1/0/0/0 0/0 "<BADREQ>"
2025-01-31T22:23:54.506970+00:00 ip-10-0-132-14 haproxy[22604]: 10.0.0.75:46138 [31/Jan/2025:22:23:54.505] test test/<NOSRV> -1/-1/-1/-1/0 400 0 - - PR-- 1/1/0/0/0 0/0 "<BADREQ>"
2025-01-31T22:23:54.554930+00:00 ip-10-0-132-14 haproxy[22604]: 10.0.0.75:43714 [31/Jan/2025:22:23:54.554] test test/<NOSRV> -1/-1/-1/-1/0 400 0 - - PR-- 1/1/0/0/0 0/0 "<BADREQ>"
2025-01-31T22:23:54.555236+00:00 ip-10-0-132-14 haproxy[22604]: 10.0.0.75:43714 [31/Jan/2025:22:23:54.554] test test/<NOSRV> -1/-1/-1/-1/0 400 0 - - PR-- 1/1/0/0/0 0/0 "<BADREQ>"
2025-01-31T22:23:54.556145+00:00 ip-10-0-132-14 haproxy[22604]: 10.0.0.75:46492 [31/Jan/2025:22:23:54.556] test test/<NOSRV> -1/-1/-1/-1/0 400 0 - - PR-- 1/1/0/0/0 0/0 "<BADREQ>"
2025-01-31T22:23:54.556200+00:00 ip-10-0-132-14 haproxy[22604]: 10.0.0.75:46492 [31/Jan/2025:22:23:54.556] test test/<NOSRV> -1/-1/-1/-1/0 400 0 - - PR-- 1/1/0/0/0 0/0 "<BADREQ>"
I’m stuck. Did I miss something obvious because I literally can’t figure out what the problem is. The request never makes it back to the webserver. It’s being blocked at the haproxy level. But even with debug logging, it doesn’t show anything useful. Nor does the admin socket:
root@ip-10-0-132-14:/usr/bin# echo "show errors" | socat /var/run/haproxy.sock stdio
Total events captured on [31/Jan/2025:23:07:17.948] : 54
[31/Jan/2025:23:05:44.834] frontend test (#2): invalid request
backend <NONE> (#-1), server <NONE> (#-1), event #53, src 10.0.0.75:61325
buffer starts at 0 (including 0 out), 15847 free,
len 537, wraps at 16336, error at position 0
H1 connection flags 0x00000000, H1 stream flags 0x00000810
H1 msg state MSG_RQBEFORE(0), H1 msg flags 0x00001400
H1 chunk len 0 bytes, H1 body len 0 bytes :
