HAProxy not starting with ssl configuration
I’m trying to set up an HTTPS/SSL frontend but HAProxy won’t start whenever I add in the ‘bind *:443 ssl crt /opt/certs/self.pem’ line. I’m not sure if there is something wrong with my config or if HAProxy doesn’t like the certificate. In saying that, I can’t see any certificate related errors in the log.
Version
HA-Proxy version 1.8.4-1deb90d 2018/02/08
Config
frontend http_front
        default_backend http_back
backend http_back
        option httpchk GET /index.html
        http-check expect string WEB
        server web1 web1.domain.com:80 check
        server web2 web2.domain.com:80 check
        bind :1234
        stats hide-version
        stats uri /
frontend ssl_front
        default_backend ssl_back
backend ssl_back
        server web1 web1.domain.com:443 check
        server web2 web2.domain.com:443 check
Certificate
I used known working certs and then tested with creating my own self signed one, but always getting the same result. Below is how I created the PEM file.
sudo openssl req -x509 -nodes -days 365 -newkey rsa:2048 -keyout /opt/certs/self.key -out /opt/certs/self.crt
cat self.crt self.key > self.pem
Logs
The logs aren’t very helpful.
Mar 31 20:01:23 centos4 haproxy: [ALERT] 089/200123 (39723) : Error(s) found in configuration file : /etc/haproxy/haproxy.cfg
Mar 31 20:01:23 centos4 haproxy: [ALERT] 089/200123 (39723) : Fatal errors found in configuration.
Mar 31 20:01:23 centos4 haproxy: Errors found in configuration file, check it with 'haproxy check'.
Mar 31 20:01:23 centos4 systemd: haproxy.service: control process exited, code=exited status=1
haproxy -dV -f haproxy.cfg
[ALERT] 089/200256 (39900) : Error(s) found in configuration file : haproxy.cfg
[ALERT] 089/200256 (39900) : Fatal errors found in configuration.
Thanks for any help.
Please share:
haproxy -vv
haproxy -c -f haproxy.cfg
Sure, see below… I must have missed this before but I do see the ‘unknown keyword ‘ssl’ error’.
haproxy -vv
  TARGET  = linux2628
  CPU     = generic
  CC      = gcc
  CFLAGS  = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement -fwrapv -Wno-unused-label
  OPTIONS =
Built without PCRE or PCRE2 support (using libc's regex instead)
Built without compression support (neither USE_ZLIB nor USE_SLZ are set).
Compression algorithms supported : identity("identity")
[ALERT] 090/011332 (8541) : parsing [haproxy.cfg:45] : 'bind *:443' unknown keyword 'ssl'. Registered keywords :
    [STAT] level <arg>
    [STAT] expose-fd <arg>
    [STAT] severity-output <arg>
    [ TCP] defer-accept
    [ TCP] interface <arg>
    [ TCP] mss <arg>
    [ TCP] tcp-ut <arg>
    [ TCP] tfo
    [ TCP] transparent
    [ TCP] v4v6
    [ TCP] v6only
    [ ALL] accept-netscaler-cip <arg>
    [ ALL] accept-proxy
    [ ALL] backlog <arg>
    [ ALL] id <arg>
    [ ALL] maxconn <arg>
    [ ALL] name <arg>
    [ ALL] nice <arg>
    [ ALL] process <arg>
    [UNIX] gid <arg>
    [UNIX] group <arg>
    [UNIX] mode <arg>
    [UNIX] uid <arg>
    [UNIX] user <arg>
[ALERT] 090/011332 (8541) : Error(s) found in configuration file : haproxy.cfg
[ALERT] 090/011332 (8541) : Fatal errors found in configuration.
Ok, haproxy has been compiled without any additional libraries, like OpenSSL, PCRE or zlib. That’s why none of those features are available.
For OpenSSL (SSL) add USE_OPENSSL=1 to your make command. PCRE (USE_PCRE=1) and zlib for compression (USE_ZLIB=1) are other libraries that you may want to use.
Unless you see some OpenSSL informations in haproxy -vv, haproxy has not been compiled with SSL support and therefor isn’t able to use it.
lukas@dev:~/haproxy$ ./haproxy -vv | grep OpenSSL
Built with OpenSSL version : OpenSSL 1.1.0h  27 Mar 2018
Running on OpenSSL version : OpenSSL 1.1.0h  27 Mar 2018
I compiled HAProxy with OpenSSL support :slight_smile:
[root@haproxy haproxy]# haproxy -vv | grep OpenSSL
But the error is still around …
Any hint ?
regards, Roberto
Is which haproxy pointing to the same executable that your startup script uses?
I just delete and recreate the symbolic link for the binary to allow to run HAProxy commands as a normal user.
sudo ln -s /usr/local/sbin/haproxy /usr/sbin/haproxy
now it works as a charme !
regards, Roberto
