Having rare ERR_SSL_PROTOCOL_ERROR error in browser while using own proxy with haproxy routing all on the server in one port. Can get error on randome websites 1+ time a day, and reloading page fix it. Before using haproxy there was no errors like this. My haproxy.cfg looks like this:
listen front
bind *:443
use_backend dns if { req.ssl_sni -m end dns.domain }
use_backend panel if { req.ssl_sni -m end panel.domain }
use_backend reality if { req.ssl_sni -m end discordapp.com }
default_backend fallback
backend dns
server adguard 127.0.0.1:1444
backend panel
server srv1 127.0.0.1:10000
backend fallback
server srv1 127.0.0.1:11000
backend reality
server srv1 127.0.0.1:12000 send-proxy
