Hi
I want to setup HAproxy with HTTPS frontend SSL offload and use SNI for different subdomains. But i have one problem. First request from web browser is forwarded to proper backend but when i reload website i get every time only MS Exchange backend even for other subdomains . Any idea thanks ?
HAproxy version: 2.3 (Debian)
HAproxy-wi: 5.1.2.0
stats socket 127.0.0.1:1999 level admin
stats socket /var/run/haproxy.sock mode 600 level admin
server-state-file /etc/haproxy/haproxy.state
bind 127.0.0.1:8085
stats uri /stats
stats realm HAProxy-04\ Statistics
stats auth admin:pass
stats admin if TRUE
frontend https_haproxy
bind 192.168.0.141:443
maxconn 2000
tcp-request inspect-delay 10s
# GeoIP & IP filtering
acl acl_DE src -f /etc/haproxy/geoip/DE.subnets
acl acl_SK src -f /etc/haproxy/geoip/SK.subnets
acl acl_local src -f /etc/haproxy/geoip/local.subnets
# server01 configuration
acl acl_server1 req_ssl_sni -i server1.domain.com
use_backend https_server01 if acl_server1
# server02 configuration
acl acl_server2 req_ssl_sni -i server2.domain.com
use_backend https_server02 if acl_server2
option ssl-hello-chk
server 192.168.0.133 192.168.0.133:443
server 192.168.0.84 192.168.0.84:443
Very thanks for help.
