Issue with ISS backend
Hi !
Since we have updated our linux server, HAProxy are uanble to connect to our IIS backend server
Before the update, everything worked fine, even if the certificat on IIS was self-seigned and expired.
And can connect with FireFox, Chrome, Edge localy on the backend server with TLS 1.2 cipher TLS_ECDHE_RSA_WITH_AES_256_CBC_SHA
I’m running HAProxy 2.4.22, the version available on Ubuntu 22.04.03
I have tried many thing, but now, I’m out of idea.
Thank you
Here is our config :
        log /dev/log    local0
        log /dev/log    local1 notice
        ssl-default-bind-options ssl-min-ver TLSv1.1 no-tls-tickets
        ssl-default-bind-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:@SECLEVEL=1
        log     global
        mode    http
        option  forwardfor
        option  httplog
        option  dontlognull
        timeout client  50000
        timeout server  100000
frontend Local_Server
        bind *:443 ssl crt /etc/haproxy/ssl_self/domain.ca.pem crt /etc/haproxy/ssl/
        acl rdgw_path path_beg -i /remoteDesktopGateway/
        acl dns_sub hdr(host) sub.domain.ca
        http-request deny if rdgw_path dns_sub
        redirect scheme https code 301 if !host_allow_http !{ ssl_fc }
        use_backend Other_Server if { ssl_fc_sni sub.domain.ca }
        default_backend Backend_ServerHTTP
    server letsencrypt 127.0.0.1:83
    option forwardfor header X-Client
    server noname 192.168.18.14:80
        timeout connect 4s
        timeout server 300s
        option httpchk GET /RDWeb
        cookie RDGW insert nocache
        server srv-1 192.168.0.30:443 check ssl verify none force-tlsv11
Here is the log after a restart of haproxy
Jan 11 16:34:29 srv-ubuntux64 haproxy[53339]: [WARNING]  (53339) : Exiting Master process...
Jan 11 16:34:29 srv-ubuntux64 haproxy[53339]: [NOTICE]   (53339) : haproxy version is 2.4.22-0ubuntu0.22.04.3
Jan 11 16:34:29 srv-ubuntux64 haproxy[53339]: [NOTICE]   (53339) : path to executable is /usr/sbin/haproxy
Jan 11 16:34:29 srv-ubuntux64 haproxy[53339]: [ALERT]    (53339) : Current worker #1 (53341) exited with code 143 (Terminated)
Jan 11 16:34:29 srv-ubuntux64 haproxy[53339]: [WARNING]  (53339) : All workers exited. Exiting... (0)
Jan 11 16:34:30 srv-ubuntux64 haproxy[57679]: [NOTICE]   (57679) : New worker #1 (57681) forked
Jan 11 16:34:32 srv-ubuntux64 haproxy[57681]: Server Other_Server/srv-1 is DOWN, reason: Layer6 invalid response, info: "SSL handshake failure", check duration: 7ms. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
Jan 11 16:34:32 srv-ubuntux64 haproxy[57681]: backend Other_Server has no server available!
Jan 11 16:34:32 srv-ubuntux64 haproxy[57681]: [WARNING]  (57681) : Server Other_Server/srv-1 is DOWN, reason: Layer6 invalid response, info: "SSL handshake failure", check duration: 7ms. 0 active and 0 backup servers left. 0 sessions active, 0 requeued, 0 remaining in queue.
Jan 11 16:34:32 srv-ubuntux64 haproxy[57681]: [NOTICE]   (57681) : haproxy version is 2.4.22-0ubuntu0.22.04.3
Jan 11 16:34:32 srv-ubuntux64 haproxy[57681]: [NOTICE]   (57681) : path to executable is /usr/sbin/haproxy
Jan 11 16:34:32 srv-ubuntux64 haproxy[57681]: [ALERT]    (57681) : backend 'Other_Server' has no server available!
Here is the result of " curl -vv https://srv-1:443 "
*   Trying 192.168.0.30:443...
* Connected to srv-1 (192.168.0.30) port 443 (#0)
* ALPN, offering h2
* ALPN, offering http/1.1
*  CAfile: /etc/ssl/certs/ca-certificates.crt
*  CApath: /etc/ssl/certs
* TLSv1.0 (OUT), TLS header, Certificate Status (22):
* TLSv1.3 (OUT), TLS handshake, Client hello (1):
* OpenSSL SSL_connect: Connection reset by peer in connection to srv-1:443
* Closing connection 0
* TLSv1.0 (OUT), TLS header, Unknown (21):
* TLSv1.3 (OUT), TLS alert, decode error (562):
curl: (35) OpenSSL SSL_connect: Connection reset by peer in connection to srv-1:443
And with " openssl s_client -connect srv-1:443 "
CONNECTED(00000003)
write:errno=104
no peer certificate available
SSL handshake has read 0 bytes and written 297 bytes
Verification: OK
New, (NONE), Cipher is (NONE)
Secure Renegotiation IS NOT supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
Early data was not sent
Verify return code: 0 (ok)
And with " openssl s_client -connect srv-1:443 -tls1_1 "
CONNECTED(00000003)
Can't use SSL_get_servername
depth=0 CN = SRV-1
verify error:num=18:self-signed certificate
verify return:1
depth=0 CN = SRV-1
verify error:num=10:certificate has expired
notAfter=Jan 14 00:00:00 2021 GMT
verify return:1
depth=0 CN = SRV-1
verify return:1
4097321C9A7F0000:error:0A0C0103:SSL routines:tls_process_key_exchange:internal error:../ssl/statem/statem_clnt.c:2248:
Certificate chain
 0 s:CN = SRV-1
   i:CN = SRV-1
   a:PKEY: rsaEncryption, 2048 (bit); sigalg: RSA-SHA1
   v:NotBefore: Jan 14 15:14:29 2020 GMT; NotAfter: Jan 14 00:00:00 2021 GMT
Server certificate
-----BEGIN CERTIFICATE-----
MIIDAjCCAeqgAwIBAgIQORyVs1VB6btMoF3PFz2GojANBgkqhkiG9w0BAQUFADAq
lZ7AGZJs
-----END CERTIFICATE-----
subject=CN = SRV-1
issuer=CN = SRV-1
Server Temp Key: ECDH, prime256v1, 256 bits
SSL handshake has read 1209 bytes and written 111 bytes
Verification error: certificate has expired
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.1
    Cipher    : 0000
    Session-ID: 714C0000440E751B6CFD83BD164C14A2E784C0C710FAAEA8BD0481C9DD990637
    Session-ID-ctx:
    Master-Key:
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    Start Time: 1704991784
    Timeout   : 7200 (sec)
    Verify return code: 10 (certificate has expired)
    Extended master secret: yes
I suggest remove the force-tlsv1.1 option in the backend server and configured add to the global section:
ssl-default-server-options ssl-min-ver TLSv1.0 no-tls-tickets
ssl-default-server-ciphers ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-RSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES256-SHA256:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:TLS_AES_128_GCM_SHA256:TLS_AES_256_GCM_SHA384:TLS_CHACHA20_POLY1305_SHA256:@SECLEVEL=0
Note that this is ssl-default-server not what you already have ssl-default-bind (which you already have in your configuration).
I copied the ciphers from your existing list but dropped the SECLEVEL to 0.
Thank you Lukas
I played with the ssl-default-bind-* options, but it wasn’t the right one.
I needed to configure the ssl-default-server-* options.
