SessionExpiry resetting ever 3 minutes?
I use a Tomcat-based app and haproxy. It has worked fine and overall it doesn’t have any issues (use JSESSIONID as the cookie to maintain session). But I tried to add the following code to my app in order to give users a 1 minute warning when their session will timeout and then auto-log them out if it has expired:
On JUST Tomcat, this works as expected. BUT if I am using haproxy in front of the app, the sessionExpiry cookie’s value is getting reset every 3 minutes ? Is there a reason for this? Is there a way to disable this?
Share you configuration please, especially regarding timeouts, load-balancing, cookie insertion and server selection.
Ok, here it is stripped of any personal data … another note, we have the EXACT same config on another server and it doesn’t have the issue at all? I can’t understand why this server is randomly updating a cookie value? Haproxy.cfg (remember we are using Tomcat on the backend):
# For more information, see ciphers(1SSL).
maxconn 10000
maxconn 60000
timeout connect 10000
timeout client 30m
timeout server 30m
errorfile 500 /usr/local/telmast/www/connection_error.html
errorfile 503 /usr/local/telmast/www/connection_error.html
frontend www-http
bind 10.X.X.X:80
frontend www-https
bind 10.X.X.X:443 ssl crt /usr/local/app/soft/ssl/private.keystore.pem
rspirep ^Location:\ http://(.*) Location:\ https://\1
acl url_demolab path_dir demolab
use_backend demolab if url_demolab
backend demolab
cookie JSESSIONID indirect nocache
server s1 10.X.Y.Y:80 check cookie s1
I figured it out :frowning: So we have a bunch of apps hosted at say something.hosted.com under their own sup path like /app1
Well the code that was making the session timeout cookie was setting the path as root (or slash) … it should have been using path ‘/app1’. So the browser, if you’ve been to more than one of these sites, was confused as to WHICH cookie it’s pulling because the ‘cookies’ for something.hosted.com would be ALL the apps not just app1.
