Dear all:
I just installed haproxy-1.8.4 and configured it as basic roundrobin setup, however I find phpmyadmin could not login as every time I typed login ID and password and click Login it will bring forward to next backend server and hence I get a new session ID, so I googled for dualing with cookie/session and find it could be solved by inserting “cookie SESSIONID insert postonly indirect” within the backend section, however after this statement I find it will not go to next server anymore.
Below is my configuration file, anything I am wrong ?
maxconn 256
#user haproxy
#group haproxy
log /var/log local0
log /var/log local1 notice
stats socket /var/run/haproxy/admin.sock mode 660 level admin
#ca-base /etc/ssl/certs
#crt-base /etc/ssl/private
timeout connect 5000ms
timeout client 50000ms
timeout server 50000ms
frontend http-800-in
bind *:800 #This port will route to default port 80 defined by below “backend server” section
default_backend servers
backend servers
#Add this below to get the clients actually IP address. Without this,
#our application would instead see every incoming request as coming from the load balancer’s IP address
#Add this to let our applications knows what port to use when redirecting/generating URLs
#http-request add-header X-Forwarded-Proto https if { ssl_fc }
option httpchk HEAD / HTTP/1.1\r\nHost:localhost
### Below is for http-auth feature ###
acl draw-auth http_auth(auth_list)
http-request auth realm draw unless draw-auth
#Below is our backend server list
server ET-POC-RH01 123.45.67.8:80 check cookie check
server ET-POC-RH02 123.45.67.9:80 check cookie check
server ET-POC-RH03 123.45.67.10:80 check cookie check
