I need help in configuring haproxy. I have an application which is authenticated using keycloak server. Here I am trying to configure 2 keycloak servers for my application for load balancing.
backend backendnodes
server server1 KEYCLOAK_SERVER1_IP:PORT check
server server2 KEYCLOAK_SERVER2_IP:PORT check
I am new in this and this is the configuration I am trying right now. If I am commenting one of the backend servers it works fine. If both the servers are enabled in backend section, request goes to both servers at same time and redirection issue happens when logging into the website. What needs to be done to fix this so that first request goes to server1 and second request goes to server 2. Thanks in advance.
This is wrong. You can’t specify URI’s here. The syntax is IP:port
No. A request either goes to one server or another.
Caused by load-balancing, most likely, you will to stick a client to a specific server, because server1 doesn’t know anything about the session on server2 and vice versa, so when haproxy load-balances between the two, those servers get confused.
That’s what already happens and is the root cause for your issue.
To fix it, we need to configure haproxy to stop doing this.
Replace balance roundrobin with balance source, so the clients source IP address is hashed and used for the server selection.
There are other way, like adding cookies for server persistence.
cookie AUTH_SESSION_ID prefix nocache
option forwardfor #http-request set-header X-Forwarded-Port %[dst_port] #http-request add-header X-Forwarded-Proto https if { ssl_fc } #option httpchk HEAD / HTTP/1.1\r\nHost:localhost
server keynd1 KEYCLOAK_SERVER1_IP:PORT check cookie keynd1
server keynd2 KEYCLOAK_SERVER2_IP:PORT check cookie keynd2
Since I am working with keycloak servers, I think AUTH_SESSION_ID is the cookie that I should use for enabling the sticky sessions. How do we include HTTP headers in haproxy? With this above given configuration I am able to get the keycloak login screen, but getting forbidden error after logging in. How to fix this issue?
