Haproxy configuration help
hello i’m trying to setup haproxy where the session sticks to the backend server used by 443 connection. So the tcp ports use the same backend server that was used in the http/443 connection. Also, is there another way to assign a unique cooke/id for a client instead of using IP
frontend infoos-https
bind *:443 ssl crt /etc/haproxy/ssl.net.pem
reqadd X-Forward-Proto:\ https
default_backend infoos
bind *:555
bind *:1443
bind *:7443
bind *:8983
bind *:9200
bind *:9543
bind *:9680
bind *:29090
bind *:29091
bind *:29092
default_backend infoos2
backend infoos
default-server inter 2s rise 2 fall 10
stick on src table infoos2
server infoos1 10.200.1.212 ssl verify none check port 443 cookie infoos1
server infoos2 10.200.1.211 ssl verify none check port 443 cookie infoos2
backend infoos2
stick-table type ip size 500k expire 8h
stick on src
server infoos1 10.200.1.212 check port 443 cookie infoos1
server infoos2 10.200.1.211 check port 443 cookie infoos2
