Handling large (500k req/sec) attacks that manage to overwhelm HAProxy 2.6.19
I’ve been facing a pretty difficult challenge over the past couple of months with large repetitive attacks which peak at 500k+ req/sec.
For many years, the rate limiting directives that I have in place have worked great (even as far back as HAProxy 1.5), however, after attackers switched to using HTTP/2, something changed and I’ve started facing issues (specifically, HAProxy gets overwhelmed, memory usage spikes to 20 / 30+ GB, and load also increases (due to the swap I/O and CPU usage).
I’ve upgraded to HAProxy 1.8 and I’m currently on 2.6.19, tested various potential improvements, but so far the LB is still overwhelmed during these large attacks.
First of all, here is my current HAProxy config (with some less important parts removed, since I’m confident that they are not relevant to this issue):
    log         127.0.0.1 local2 notice
    chroot      /var/lib/haproxy
    maxconn     300000
    user        haproxy
    group       haproxy
    nbthread    12
    cpu-map auto:1/1-12 0-11
    tune.ssl.cachesize 50000
    tune.ssl.lifetime 300
    tune.http.cookielen 512
    # turn on stats unix socket
    stats socket /var/lib/haproxy/stats mode 755 user nrpe level admin
    ssl-default-server-ciphers PROFILE=SYSTEM
    option                  http-server-close
    option                  log-health-checks
    option                  tcp-smart-accept
    option                  tcp-smart-connect
    option                  logasap
    ## Keeping retries disabled as well, because it's very likely that it causes a domino effect during attacks
    retries                 0
    timeout connect         3s
    timeout client           5s ## it was 30 in the past, now testing 5 to see how it goes
    timeout server           5s ## it was 30 in the past, now testing 5 to see how it goes
    timeout client-fin       1s
    timeout server-fin       1s
    timeout queue            2s
    timeout http-request     3s
    timeout http-keep-alive  5s
    timeout check           10s
    maxconn                 50000
listen     lb_statistics
   bind    xx.xx.xx.xx:8080 ssl crt /etc/haproxy/ssl/mycrt.pem alpn h2
   mode    http
   server  lb1 127.0.0.1:80
   stats   uri /
   stats   realm "HAProxy Stats"
   stats   auth <user>:<password>
frontend prod_website
    bind xx.xx.xx.xx:80
    bind xx.xx.xx.xx:443 ssl crt /etc/haproxy/ssl/mycrt.pem alpn h2,http/1.1
    maxconn 100000
## Disabled for now, since it seems to cause even worse behavior during attacks
#    option http-buffer-request
    log 127.0.0.1 local3
    capture request header User-Agent len 256
    capture request header Referer len 128
    capture cookie my.custom.Token len 512
    tcp-request inspect-delay 1s
    acl website_prod_is_http dst_port 80
    acl website_prod_is_ssl dst_port 443
    ## ACL for missing User agent header
    acl missing_ua hdr_cnt(user-agent) eq 0
    acl all_whitelisted_ips src -f /etc/haproxy/all_whitelisted_ips.lst
    ## Track connection counters
    tcp-request session track-sc2 src table website_connection_abuse if !all_whitelisted_ips
##    tcp-request connection track-sc2 src table website_connection_abuse if !all_whitelisted_ips
    # Limiting the connection rate per client. No more than 200 connections over 3 seconds.
    tcp-request content reject if { src_conn_rate(website_connection_abuse) ge 200 } !all_whitelisted_ips
##    tcp-request connection reject if { src_conn_rate(website_connection_abuse) ge 200 } !all_whitelisted_ips
    # Reject if more than 200 connections from client.
    tcp-request content reject if { src_conn_cur(website_connection_abuse) ge 200 } !all_whitelisted_ips
##    tcp-request connection reject if { src_conn_cur(website_connection_abuse) ge 200 } !all_whitelisted_ips
    acl website_too_many_requests_1 sc0_gpc0_rate(website_dummy_sticktable1) ge 300
    acl website_mark_seen_1 sc0_inc_gpc0(website_dummy_sticktable1) gt 0
##    tcp-request content track-sc0 src table website_dummy_sticktable1 if !all_whitelisted_ips
    http-request track-sc0 src table website_dummy_sticktable1 if !all_whitelisted_ips
    ## Requested by Benjamin on December 5th, 2023
    acl website_too_many_requests_2 sc1_gpc0_rate(website_dummy_sticktable2) ge 100
    acl website_mark_seen_2 sc1_inc_gpc0(website_dummy_sticktable2) gt 0
##    tcp-request content track-sc1 src,ipmask(24) table website_dummy_sticktable2 if !all_whitelisted_ips
    http-request track-sc1 src,ipmask(24) table website_dummy_sticktable2 if !all_whitelisted_ips
    # Deny requests with no user-agent header
    http-request deny if missing_ua
    http-request set-header X-Forwarded-Proto https if website_prod_is_ssl
    redirect scheme https code 301 if website_prod_is_http !is_asmx_path !is_ads_url
    use_backend website_rate_limiting if !all_whitelisted_ips !blacklisted-ips website_mark_seen_1 website_too_many_requests_1
    use_backend website_rate_limiting2 if !all_whitelisted_ips !blacklisted-ips website_mark_seen_2 website_too_many_requests_2
    default_backend website_prod_nodes
    mode    http
    http-request del-header ^X-Forwarded-For:.*
    timeout queue    1s
    http-check send meth GET uri /status ver HTTP/1.1 hdr Host www.mywebsite.com hdr User-Agent HAProxyLB
    http-check expect string OK
    server  prod-node01 192.168.1.11:80 weight 5 check inter 10s rise 2 fall 5 maxconn 300 maxqueue 100
    server  prod-node02 192.168.1.12:80 weight 5 check inter 10s rise 2 fall 5 maxconn 300 maxqueue 100
    server  prod-node03 192.168.1.13:80 weight 5 check inter 10s rise 2 fall 5 maxconn 300 maxqueue 100
    server  prod-node04 192.168.1.14:80 weight 5 check inter 10s rise 2 fall 5 maxconn 300 maxqueue 100
    server  prod-node05 192.168.1.15:80 weight 5 check inter 10s rise 2 fall 5 maxconn 300 maxqueue 100
    server  prod-node06 192.168.1.16:80 weight 5 check inter 10s rise 2 fall 5 maxconn 300 maxqueue 100
    server  prod-node07 192.168.1.17:80 weight 5 check inter 10s rise 2 fall 5 maxconn 300 maxqueue 100
    server  prod-node08 192.168.1.18:80 weight 5 check inter 10s rise 2 fall 5 maxconn 300 maxqueue 100
backend website_dummy_sticktable1
    stick-table type ip size 500k expire 30m store gpc0_rate(5m)
backend website_dummy_sticktable2
backend website_connection_abuse
    stick-table type ip size 500k expire 30m store conn_rate(3s),conn_cur
    timeout tarpit 2s
    errorfile 500 /etc/haproxy/errorfiles/429_http
    http-request tarpit
##    http-request silent-drop
    timeout tarpit 2s
    http-request tarpit
Also, here is a small log sample from the last attack:
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_1>:46199 [21/Oct/2024:10:16:59.018] prod_website~ prod_website/<NOSRV> -1/-1/-1/-1/2988 0 0 - - PR-- 9047/8373/0/0/0 0/0 "<BADREQ>"
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_2>:46931 [21/Oct/2024:10:17:00.599] prod_website~ prod_website/<NOSRV> -1/-1/-1/-1/1407 0 0 - - PR-- 9047/8373/0/0/0 0/0 "<BADREQ>"
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_3>:15801 [21/Oct/2024:10:16:59.656] prod_website~ prod_website/<NOSRV> -1/-1/-1/-1/2351 0 0 - - PR-- 9047/8373/0/0/0 0/0 "<BADREQ>"
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_4>:33986 [21/Oct/2024:10:17:01.831] prod_website~ prod_website/<NOSRV> -1/-1/-1/-1/174 0 0 - - PR-- 9047/8373/0/0/0 0/0 "<BADREQ>"
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_5>:46370 [21/Oct/2024:10:17:01.965] prod_website~ prod_website/<NOSRV> -1/-1/-1/-1/42 0 0 - - PR-- 9047/8373/0/0/0 0/0 "<BADREQ>"
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_6>:15915 [21/Oct/2024:10:17:00.902] prod_website~ prod_website/<NOSRV> -1/-1/-1/-1/1099 0 0 - - PR-- 9047/8373/0/0/0 0/0 "<BADREQ>"
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_7>:5555 [21/Oct/2024:10:16:59.684] prod_website~ website_rate_limiting/<NOSRV> -1/2328/-1/-1/2327 500 274 - - PT-- 9047/8373/76013/0/0 0/0 {Dalvik/
2.1.0 (Linux; U; Android 12; Pixel 6 Pro Build/SD1A.210817.036)|} "GET https://www.mywebsite.com HTTP/2.0"
Oct 21 10:17:01 localhost haproxy[2388065]: <malicious_ip_4>:34019 [21/Oct/2024:10:17:00.976] prod_website~ prod_website/<NOSRV> -1/-1/-1/-1/1009 0 0 - - PR-- 9047/8373/0/0/0 0/0 "<BADREQ>"
Oct 21 10:17:01 localhost haproxy[2388065]: <malicious_ip_1>:23959 [21/Oct/2024:10:17:01.462] prod_website~ prod_website/<NOSRV> -1/-1/-1/-1/532 0 0 - - PR-- 9047/8373/0/0/0 0/0 "<BADREQ>"
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_8>:51268 [21/Oct/2024:10:17:00.742] prod_website~ prod_website/<NOSRV> -1/-1/-1/-1/1266 0 0 - - PR-- 9047/8373/0/0/0 0/0 "<BADREQ>"
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_9>:47490 [21/Oct/2024:10:17:01.173] prod_website~ prod_website/<NOSRV> -1/-1/-1/-1/828 0 0 - - PR-- 9047/8373/0/0/0 0/0 "<BADREQ>"
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_10>:34619 [21/Oct/2024:10:17:01.629] prod_website~ prod_website/<NOSRV> -1/-1/-1/-1/382 0 0 - - PR-- 9047/8373/0/0/0 0/0 "<BADREQ>"
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_7>:5555 [21/Oct/2024:10:16:59.684] prod_website~ website_rate_limiting/<NOSRV> -1/2328/-1/-1/2327 500 274 - - PT-- 9047/8373/76012/0/0 0/0 {Dalvik/
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_7>:5555 [21/Oct/2024:10:16:59.684] prod_website~ website_rate_limiting/<NOSRV> -1/2328/-1/-1/2327 500 274 - - PT-- 9047/8373/76011/0/0 0/0 {Dalvik/
Oct 21 10:17:02 localhost haproxy[2388065]: <malicious_ip_7>:5555 [21/Oct/2024:10:16:59.684] prod_website~ website_rate_limiting/<NOSRV> -1/2328/-1/-1/2327 500 274 - - PT-- 9047/8373/76010/0/0 0/0 {Dalvik/
2.1.0 (Dalvik/2.1.0 (Linux; U; Android 12; Pixel 6 Pro Build/SD1A.210817.036)|} "GET https://www.mywebsite.com HTTP/2.0"
The entries that contain ‘BADREQ’ are generated by the connection rate limiting seen in the above config (the “tcp-request content reject” entries), while the others with “website_rate_limiting” fall under the http-request trackers/sticktables.
One thing that stands out to me is the fact that the connections don’t seem to actually be closed (I see the same source ports for the same IPs being used). In the documentation I see that they should be: " tcp-request content reject - Closes the connection without a response once a session has been created, but before the HTTP parser has been initialized. These requests still show in your logs."
I also tried tcp-request connection reject (I left the lines commented in the config), but they don’t seem to make much of a difference and, worst of all, they are not logged - which is a real problem (especially since I have further automation that parses the logs and blacklists abuser IPs at the layer 3 / layer 4 level - which so far has been the only thing that saved me from experiencing downtimes greater than a minute or so).
Another thing is the fact that the requests take way too long to complete (i.e.: -1/-1/-1/-1/2988). When I did my own tests, the connections were cut instantly with absolutely no delay, so what gives, how come the connections are so long-lived (with a great deal of variation)?
Last but not least, I see “website_rate_limiting” requests from the same IP, during the same second, which should be tarpitted and yet they don’t seem to be.
As of now, I’m yet to figure out if it’s an issue related to my particular configuration or maybe a yet undiscovered HAProxy bug. Any advice would be greatly appreciated. Thank you!
HAProxy is running on a pretty powerful, dedicated physical server with an Intel Xeon E-2388G CPU (8 cores / 16 threads), 32 GB RAM, and very fast NVMe storage.
Also adding my sysctl.conf for completeness:
# Reboot in 5 seconds if there's a kernel panic
kernel.panic = 5
# Discourage the kernel from swapping
vm.swappiness = 10
# Use more ports for incoming connections
net.ipv4.ip_local_port_range = 10000 65535
# Increase Linux autotuning TCP buffer limits
# # Set max to 16MB for 1GE and 32M (33554432) or 54M (56623104) for 10GE
# # Don't set tcp_mem itself! Let the kernel scale it based on RAM.
net.core.rmem_max = 16777216
net.core.wmem_max = 16777216
net.core.rmem_default = 16777216
net.core.wmem_default = 16777216
net.core.optmem_max = 40960
net.ipv4.tcp_rmem = 4096 16384 16777216
net.ipv4.tcp_wmem = 4096 8192 16777216
#net.ipv4.tcp_mem = 4096 16384 16777216
#net.ipv4.tcp_rmem = 4096 87380 16777216
#net.ipv4.tcp_wmem = 4096 65536 16777216
# Make room for more TIME_WAIT sockets due to more clients,
# # and allow them to be reused if we run out of sockets
# # Also increase the max packet backlog
net.core.netdev_max_backlog = 50000
net.ipv4.tcp_max_syn_backlog = 30000
net.ipv4.tcp_max_tw_buckets = 2000000
net.ipv4.tcp_tw_reuse = 1
# Decrease the time that sockets stay in the TIME_WAIT state
net.ipv4.tcp_fin_timeout = 5
# Disable TCP slow start on idle connections
net.ipv4.tcp_slow_start_after_idle = 0
# Disable source routing and redirects
net.ipv4.conf.all.send_redirects = 0
net.ipv4.conf.all.accept_redirects = 0
net.ipv4.conf.all.accept_source_route = 0
# Increase the max orphans and max connections
net.ipv4.tcp_max_orphans = 500000
net.ipv4.tcp_synack_retries = 2
net.core.somaxconn = 65535
# Protect Against TCP Time-Wait attack
net.ipv4.tcp_rfc1337 = 1
# Increase the maximum number of netfilter handled connections
#net.netfilter.nf_conntrack_max = 524288
net.netfilter.nf_conntrack_max = 1048576
net.netfilter.nf_conntrack_tcp_timeout_established = 54000
net.netfilter.nf_conntrack_generic_timeout = 120
# Prevent TCP SACK PANICK attack:
net.ipv4.tcp_sack = 0
what is the the HTTP/2 attack packet looks like? may you can tcpdump capture the HTTP/2 attacking packet and see if there are packet patterns, eBPF XDP maybe could be used to stop these kind of attacks from the network driver if the attacking packet pattern can be easily extracted by XDP.
Wouldn’t fail2ban help in your case? If your logs already identify the offending IPs, it would be trivial to ban them at the firewall level.
Yeah, as I mentioned this part is already covered. What I want is for HAProxy itself to be able to successfully handle the initial attack burst.
are these attack HTTP2 based, and encrypted? if not encrypted, http filter in driver like bcc/examples/networking/http_filter at master · iovisor/bcc · GitHub could be adopted to filter these attacks.
