Dear Readers,
I’m trying to set up haproxy with SNI.
I’m getting a GREEN A on SSLlabs for news.rathaus.potsdam.de
But Browsers or haproxy are ignoring my setup
with
openssl s_client -servername news.rathaus.potsdam.de -connect news.rathaus.potsdam.de:443
I see that haproxy is sending the right certificate for news.potsdam… AND asks for a Client certificate for test.potsdam…
What’s wrong with that configuration or is it simply not implemented in the way I think ?
8<------ SNIP
haproxy -vv
HA-Proxy version 1.6.9 2016/08/30
Copyright 2000-2016 Willy Tarreau <willy@haproxy.org>
TARGET = linux2628
CC = gcc
CFLAGS = -O2 -g -fno-strict-aliasing -Wdeclaration-after-statement
OPTIONS = USE_OPENSSL=1 USE_STATIC_PCRE=1
Built without compression support (neither USE_ZLIB nor USE_SLZ are set)
Compression algorithms supported : identity("identity")
Built with OpenSSL version : OpenSSL 1.0.2j 26 Sep 2016
Running on OpenSSL version : OpenSSL 1.0.2j 26 Sep 2016
Built with PCRE version : 8.38 2015-11-23
Built without Lua support
8< ---- SNIP
haproxy.cfg
stats socket /var/run/haproxy.sock level admin
nbproc 1
log 127.0.0.1:514 len 4096 local2
pidfile /var/run/haproxy.pid
# SSL DEFAULTS
ssl-default-bind-options no-sslv3 no-tls-tickets no-tlsv11
ssl-default-bind-ciphers ECDHE+aRSA+AES256+GCM+SHA384:ECDHE+aRSA+AES128+GCM+SHA256:ECDHE+aRSA+AES256+SHA384:ECDH+AESGCM:DH+AESGCM:ECDH+AES256:DH+AES256:ECDH+AES128:!aNULL:!MD5:!DSS
timeout http-request 5s
timeout connect 4s
timeout server 10s
timeout client 30s
option forwardfor # set the client's IP in X-Forwarded-For.
option splice-response
option tcp-smart-accept
option tcp-smart-connect
timeout http-keep-alive 5s
frontend www-https
# news 443 ssl crt /etc/haproxy/certs.d/news.rathaus.potsdam.de.pem
# test crt /etc/haproxy/certs.d/test.rathaus.potsdam.de.pem ca-file /etc/haproxy/certs-own/ca-svp-root-crt.pem verify required
# TWO Certs news and test whetre test is self signed an reqires an client certificate which is downloadable
# with https:/news.rathaus.potsdam.de/certs/client1.pfx pass:Potsdam2016!
bind *:443 ssl crt /etc/haproxy/certs.d/news.rathaus.potsdam.de.pem strict-sni crt /etc/haproxy/certs.d/test.rathaus.potsdam.de.pem strict-sni ca-file /etc/haproxy/certs-own/ca-svp-root-crt.pem verify required
# split up incoming URLs
acl APP_CERTS path_beg -i /certs
acl APP_RIS path_beg -i /ai
acl APP_RIS path_beg -i /bi
acl APP_PWA path_beg -i /pwa
# PWA und robots favicon
acl APP_PWA path_end -i robots.txt
acl APP_PWA path_end -i favicon.ico
# Backend Routing
use_backend server_RIS if APP_RIS-AI # --> news
use_backend server_CERTS if APP_CERTS # --> test
use_backend server_EMA if APP_EMA
use_backend server_PWA if APP_PWA
# Backend definition
option httpclose
server ZertiSchleuder 127.0.0.1:8080 maxconn 120 check
backend server_RIS
option httpclose
server ris 10.234.205.157:80 maxconn 200 check
backend server_PWA
option httpclose
http-response set-header Strict-Transport-Security "max-age=16000000; includeSubDomains; preload;"
server pwa 10.234.205.156:80 check
