Hi there!!
I’m new here and also in the HA world, in version 1.4 on the left of the web view of backends we had a check in order to disable them for maintenance…how can i get this on version 1.7?
Thks!!!
Hi there!!
Thks!!!
I don’t see what’s different in haproxy 1.7 compared to 1.4; you need stats admin mode in both. Can you share you configuration please?
Hello
Thks for your response, the config is pretty simple:
#simple config
frontend localnodes
bind *:8080
default_backend node1
backend node1
#stats hide-version
#stats scope .
#stats uri /admin?stats
#stats realm Haproxy\ Statistics
#stats auth admin1:admin1
cookie SRV_ID insert indirect nocache #prefix
#email-alert mailers mailservers
#email-alert from HAproxy93@sicof.es
#email-alert to jose@etec.es
#http-request set-header X-Forwarded-Port %[dst_port]
#http-request add-header X-Forwarded-Proto https if { ssl_fc }
#option httpchk HEAD / HTTP/1.1\r\nHost:192.168.10.93
#server 82i1 192.168.10.82:28080 check cookie C
#server 82i2 192.168.10.82:28081 check cookie C2
#option http check
server i1 192.168.10.93:28080 check cookie D
server i2 192.168.10.93:28081 check cookie D2
bind *:1936
stats hide-version
stats uri /
stats realm Haproxy
stats auth haproxy:haproxy
stats refresh 20s
Only 2 http nodes, after I’ll need to know how to balance two https servers (forward only)
THKS!!
Just like I suspected, you did not configure admin mode. Please refer to my previous post where you can find a link to the documentation explaining it.
Solved!!!
Thaks a lot
