Hello
I use this configuration. web work perfect but when i try to use ssh sometimes not working and when is working after 1 min that i am not use it is timeout. how i can fix this. how i can remove do not make me timeout. i change the ssh port on my proxy server
timeout connect 1h
timeout client 1h
timeout server 1h
frontend main
default_backend app-main
backend app-main
server web1 ip:80 check fall 3 rise 2
frontend sshd
bind *:22
default_backend ssh
timeout client 1h
backend ssh
server localhost-bitbucket-ssh ip:22
