I have 2 backend server where SSH being proxy through haproxy.
When having rapid SSH login/logout sequence, haproxy will throw connection reset error.
It normally happen after the 19th successful SSH attempt
kex_exchange_identification: Connection closed by remote host
It looks like some protection mechanism. But, I could not find any relevant default setting from the guide.
The configuration is fairly simple. shown below:
log 127.0.0.1:514 local0
stats socket /var/lib/haproxy/haproxy-stats level admin
maxconn 20000
# POODLE Hardening
peers LB
peer haproxy01 192.168.0.1:8443
peer haproxy02 192.168.0.2:8443
option logasap
frontend P22-fe
bind 192.168.100.1:22
default_backend P22-be
backend P22-be
server 192.168.1.3 192.168.1.3:22 check
server 192.168.1.4 192.168.1.4:22 check
Appreciate if someone can point me to the right direction.
