All my backends support h2. http health check is failing as it is using h2 and marking the members down. If I remove the health check then everything works fine .
How do I force the health check to happen on http/1.1 instead of h2.
backend backend_java
option http-use-htx
option httpchk GET /healthcheck HTTP/1.1
server default_1_java 1.1.1.1:443 check ssl verify none alpn h2,http/1.1
server default_2_java 2.2.2.2:443 check ssl verify none alpn h2,http/1.1
