Hello, I’m having a problem with haproxy health checks.
I have a backend that is serving the main service on HTTPS 8443 and serving a health endpoint on HTTP 9000.
Is there a way to have the haproxy health check over http while the backend server is https? My current config (which does not work) looks like this:
backend my_backend
timeout check 2000
option httpchk GET "/health" "HTTP/1.0"
cookie my-cookie insert nocache postonly domain example.com
server my_server 10.42.38.175:8443 ssl verify none check port 9000 inter 2000 rise 2 fall 3 cookie my_server
I’m thinking the issue is that because there is the ssl option on the server line, it’s expecting everything to be SSL, even the check port? Is there a way around this?
