I have this TCP proxy setup in a working config:
listen ssl
bind 127.0.0.1:443
server ssl-server 10.0.0.1:443 send-proxy
However, if I add the following check, everything breaks (except for the check that seems to work fine):
listen ssl
bind 127.0.0.1:443
server ssl-server 10.0.0.1:443 send-proxy check ssl verify none inter 3000
option httpchk GET /is_alive HTTP/1.1\r\nHost:\ example.org
Why is my ssl check leaking into my general backend connections and breaking them? Is there any way to force haproxy to shut down the connection it is using after the GET is done (and grab a new connection before it starts)
(I can think of a trivial workaround where I ask it to test a different port, but I wonder if that is really needed?)
