we’ve been using haproxy 2.5 stable, as a replacement for an older version. Since using the new version, we are experiencing a strange issue. Some resources, both static via nginx webserver and dynamic via a rest microservice show random behaviour. The requests most often work, but intermittently fail with an error 500, where haproxy signals the termination state PH–. I’ve checked for invalid headers, content-length and more, and there are none. “show errors” is not showing any errors at all. Bypassing the load-balancer solves the issue (but obviously presents a different problem).
I was wondering how to determine the root cause of this. For the dynamic resource: using ‘replay XHR’ in the browser always succeeds ;-). I have the impression it happens only when part of a series of requests…
There is no 2.5 release. Do you mean you are using 2.5.0 ? In that case, first of all, upgrade to 2.5.4 considering that 2.5.0 contains 76 known bugs, 7 of those are major bugs
I’m sorry, should have been more clear. I have the latest release, 2.5.4:
HAProxy version 2.5.4-1ppa1~focal 2022/02/25 - https://haproxy.org/
Status: stable branch - will stop receiving fixes around Q1 2023.
Known bugs: http://www.haproxy.org/bugs/bugs-2.5.4.html
Running on: Linux 5.4.0-100-generic #113-Ubuntu SMP Thu Feb 3 18:43:29 UTC 2022 x86_64
TARGET = linux-glibc
CC = cc
CFLAGS = -O2 -g -O2 -fdebug-prefix-map=/build/haproxy-7oXbgr/haproxy-2.5.4=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -Wall -Wextra -Wundef -Wdeclaration-after-statement -fwrapv -Wno-address-of-packed-member -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wno-cast-function-type -Wtype-limits -Wshift-negative-value -Wshift-overflow=2 -Wduplicated-cond -Wnull-dereference
DEBUG =
Feature list : +EPOLL -KQUEUE +NETFILTER -PCRE -PCRE_JIT +PCRE2 +PCRE2_JIT +POLL +THREAD +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL +LUA +ACCEPT4 -CLOSEFROM -ZLIB +SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL -PROCCTL +THREAD_DUMP -EVPORTS -OT -QUIC +PROMEX -MEMORY_PROFILING
Built with OpenSSL version : OpenSSL 1.1.1f 31 Mar 2020
Running on OpenSSL version : OpenSSL 1.1.1f 31 Mar 2020
Built with gcc compiler version 9.3.0
h2 : mode=HTTP side=FE|BE mux=H2 flags=HTX|CLEAN_ABRT|HOL_RISK|NO_UPG
[FCGI] fcgi-app
Some more info. This is what appears in the log. Enabling debug mode, the headers appear. There are no duplicates, caching headers or invalid content-length. I have the issue both with static chunked resources, and a couple of rest endpoints.
Mar 4 13:58:19 load-balancer-1 haproxy[1491]: 2a02:<redacted>:57887 [04/Mar/2022:13:58:19.181] https~ dashboard-tst/dashboard-tst 0/0/0/-1/47 500 15424 - - PH-- 5/5/2/2/0 0/0 "GET /js/polyfills.c86610ad4dcc15e804f1.js?c86610ad4dcc15e804f1 HTTP/1.1"
Show errors, shows a frontend invalid request (just to check if that works), but nothing on the response in question…
[04/Mar/2022:18:05:37.829] frontend http (#2): invalid request
backend <NONE> (#-1), server <NONE> (#-1), event #0, src ::ffff:66.240.205.34:53678
buffer starts at 0 (including 0 out), 16308 free,
len 76, wraps at 16336, error at position 1
H1 connection flags 0x00000100, H1 stream flags 0x00000810
H1 msg state MSG_RQMETH(2), H1 msg flags 0x00001400
H1 chunk len 0 bytes, H1 body len 0 bytes :
00000 H\x00\x00\x00tj\xA8\x9E#D\x98+\xCA\xF0\xA7\xBBl\xC5\x19\xD7\x8D\xB6
00022+ \x18\xEDJ\x1En\xC1\xF9xu[l\xF0E\x1D-j\xEC\xD4xL\xC9r\xC9\x15\x10u\xE0%
00050+ \x86Rtg\x05fv\x86]%\xCC\x80\x0C\xE8\xCF\xAE\x00\xB5\xC0f\xC8\x8DD\xC5
00074+ \t\xF4
This is what happens in the browser. The first request is triggered by javascript, the next by clicking ‘replay xhr’. No modifications on the reverse proxy in any way…
Please file a bug on github:
Resolved: the rewrite buffer was too small. Adding tune.rewrite 1024 resolved it. The issue that there is no error reporting remains.
