Hi!
I am trying to use haproxy to direct users to different backends depending on the url in the browser.
All the backends have the same real URL (https://<backend>:8443/backurl).
But with my configuration, haproxy always uses default backend to serve the page, after rewriting.
Please how can I fix this, and make haproxy use only the designated backend, instead of using the default?
Also when I remove the default backend line, haproxy returns a 503 error message.
frontend incoming-in
bind *:443 ssl crt /usr/local/etc/haproxy/ssl/domain.pem
cookie SRVNAME insert
reqadd X-Forwarded-Port:\ 443
# set HTTP Strict Transport Security (HTST) header
rspadd Strict-Transport-Security:\ max-age=15768000
#ACLs and URL rewrites...
acl url_1 url_beg /back1url
acl url_2 url_beg /back2url
acl url_3 url_beg /back3url
use_backend back_1-backurl if url_1
use_backend back_3-backurl if url_3
use_backend back_2-backurl if url_2
default_backend back_1-backurl
reqrep ^([^\ ]*\ /)back1url[/]?(.*) \1backurl\2
server back_1 10.0.1.202:8443 cookie back_1 ssl verify none
reqrep ^([^\ ]*\ /)back2url[/]?(.*) \1backurl\2
server back_2 10.0.1.200:8443 cookie back_2 ssl verify none
reqrep ^([^\ ]*\ /)back3url[/]?(.*) \1backurl\2
server back_3 10.0.1.233:8443 cookie back_3 ssl verify none`
Thanks a lot in advance!
