How redirect specific url path to another backend?
here is my config please check
# See: https://ssl-config.mozilla.org/#server=haproxy&ser...
frontend front
bind :443 ssl crt /etc/my_sls/
acl url_example hdr(host) -i example.com www.example.com
use_backend URL_example if url_example
use_backend api.example if url_example { path -m beg -i /auth/login/ }
backend URL_example
server web1 10.10.11.10:8080
backend api.example
server web1 10.10.11.10:8890/auth/login/
Order matters. Flip these two lines:
thanks
