Haproxy and url rewrites to internal servers and urls
i have a few external websites which now works with nginx. As i need to host an internal exchange 2013 server (which free nginx doesn’t like) i am looking into haproxy.
I have some urls which i now use like mail.lex-it.com, wiki.lex-it.com and helpdesk.lex-it.com
https://mail.lex-it.com needs to be redirected to the internal exchange 2013 servers
https://wiki.lex-it.com needs to be redirected using url rewrite to internal server https://wiki.lan.local/xwiki
https://helpdesk.lex-it.com needs to be redirected to just an internal server https://helpdesk.lan.local (no further url rewrite)
The mail i still need to figure out but as i am new to the haproxy just wanted to focus in the simpler websites.
The problem i face is with the wiki rewrite which i don’t know how to do and i hope one off you can help me with this.
I have managed to create the following config, but the wiki is bogus offcourse :slight_smile: :
        log 127.0.0.1   local0
        log 127.0.0.1   local1 notice
        maxconn 25000
        log     global
        mode    http
        option  httplog
        option  dontlognull
        option  forwardfor
        option  http-server-close
        stats   enable
        # stats auth someuser:somepassword
        stats uri /haproxy?stats
frontend http-in
        bind *:443
        # Define hosts
        acl host_helpdesk hdr(host) -i helpdesk.lex-it.com
        acl host_wiki hdr(host) -i wiki.lex-it.com
        ## figure out which one to use
        use_backend helpdesk_cluster if host_helpdesk
        use_backend wiki_cluster if host_wiki
        option httpclose
        cookie JSESSIONID prefix
        server node1 helpdesk.lan.local cookie A check
        option httpclose
        server node1 wiki.lan.local/xwiki cookie A check
I managed with lots of help from google to have most of the options i need.
With this config i have my exchange services fully operational and my 2 internal websites are available based on the host header.
This means i don’t need my nginx proxy anymore :slight_smile:
I still however need to rewrite my wiki.lex-it.com to wiki.lex-it.com/xwiki
This i haven’t managed yet and help would really be appreciated
for google i add the search words: haproxy exchange 2013 exchange 2016 host header https forward
haproxy.cfg
   log 127.0.0.1 local1 debug
   stats socket /var/lib/haproxy/stats mode 660 level admin
   ssl-server-verify none
   crt-base /etc/pki/tls/certs
   ca-base /etc/pki/tls/certs
   option prefer-last-server
   no option httpclose
   no option http-server-close
   no option forceclose
   no option http-tunnel
   default-server inter 3s rise 2 fall 3
   timeout client 600s
   timeout http-request 10s
   timeout connect 4s
   timeout server 60s
frontend ft_default_http
   bind *:80 name http
   mode    http
   option  httplog
   # show stats in http mode
   stats   enable
   # redirect all other trafic to https
frontend ft_default_https
   bind *:443 name https ssl crt /etc/pki/tls/certs/lex-it.com.pem
   capture response header Content-Length len 10
   log-format %ci:%cp\ [%t]\ %ft\ %b/%s\ %Tq/%Tw/%Tc/%Tr/%Tt\ %ST\ %B\ %CC\ %CS\ %tsc\ %ac/%fc/%bc/%sc/%rc\ %sq/%bq\ %hr\ %hs\ {%sslv/%sslc/%[ssl_fc_sni]/%[ssl_fc_session_i
d]}\ "%[capture.req.method]\ %[capture.req.hdr(0)]%[capture.req.uri]\ HTTP/1.1"
   option socket-stats
   stats realm Strictly\ Private
   stats auth YOURSTATLOGINUSER:YOURSTATLOGINPASSWORD
   maxconn 1000
   acl ssl_connection ssl_fc
   acl host_mail hdr(Host) -i mail.lex-it.com
   acl host_helpdesk hdr(Host) -i helpdesk.lex-it.com
   acl host_wiki hdr(Host) -i wiki.lex-it.com
   acl path_slash path /
   acl path_autodiscover path_beg -i /Autodiscover/Autodiscover.xml
   acl path_activesync path_beg -i /Microsoft-Server-ActiveSync
   acl path_ews path_beg -i /ews/
   acl path_owa path_beg -i /owa/
   acl path_oa path_beg -i /rpc/rpcproxy.dll
   acl path_ecp path_beg -i /ecp/
   acl path_oab path_beg -i /oab/
   acl path_mapi path_beg -i /mapi/
   acl path_check path_end -i HealthCheck.htm
   http-request deny if path_check
   http-request redirect scheme https code 302 unless ssl_connection
   http-request redirect location /owa/ code 302 if path_slash host_mail
   use_backend bk_exchange_https_autodiscover if path_autodiscover
   use_backend bk_exchange_https_activesync if path_activesync
   use_backend bk_exchange_https_ews if path_ews
   use_backend bk_exchange_https_owa if path_owa
   use_backend bk_exchange_https_oa if path_oa
   use_backend bk_exchange_https_ecp if path_ecp
   use_backend bk_exchange_https_oab if path_oab
   use_backend bk_exchange_https_mapi if path_mapi
   use_backend bk_helpdesk if host_helpdesk
   use_backend bk_wiki if host_wiki
   default_backend bk_exchange_https_default
   option httpchk GET /Microsoft-Server-ActiveSync/HealthCheck.htm
   http-check expect string 200\ OK
   server mail1 10.1.0.5:443 ssl verify none maxconn 1000 weight 10 check
   option httpchk GET /Autodiscover/HealthCheck.htm
   option httpchk GET /ECP/HealthCheck.htm
   option httpchk GET /EWS/HealthCheck.htm
   option httpchk GET /mapi/HealthCheck.htm
   timeout server 600s
   option httpchk GET /OAB/HealthCheck.htm
   option httpchk GET /RPC/HealthCheck.htm
   timeout server 600s
   option httpchk GET /owa/HealthCheck.htm
   timeout server 60s
#frontend ft_exchange_smtp
# mode tcp
# bind 10.1.1.22:25 name smtp
# maxconn 10000
# default_backend bk_exchange_smtp
#backend bk_exchange_smtp
# mode tcp
# server mail1 10.1.0.5:25 maxconn 10000 weight 10 check
#frontend ft_exchange_smtps
# mode tcp
# bind 10.1.1.22:587 name smtps
# maxconn 10000
# default_backend bk_exchange_smtps
#backend bk_exchange_smtps
# mode tcp
# server mail1 10.1.0.5:587 maxconn 10000 weight 10 check
#frontend ft_exchange_imaps
# mode tcp
# bind 10.1.1.22:993 name imaps
# maxconn 10000
# default_backend bk_exchange_imaps
#backend bk_exchange_imaps
# mode tcp
# balance leastconn
# stick store-request src
# stick-table type ip size 200k expire 30m
# server mail1 10.1.0.5:993 maxconn 10000 weight 10 check
backend bk_helpdesk
   option httpclose
   server helpdesk1 10.1.0.22:443 ssl verify none maxconn 1000 weight 10 check
backend bk_wiki
   option httpclose
   server wiki1 10.1.0.22:443 ssl verify none maxconn 1000 weight 10 check
if i add code
http-request redirect code 301 location https://wiki.lex-it.com/xwiki if { hdr(host) -i wiki.lex-it.com }
it gets in a loop as i can asume. I only need to rewrite if there is nothing at the end of the url e.g. wiki.lex-it.com/
Still searching for a solution, anyone ??
Eureka, i found it…
I needed to add the following in my backend:
  acl p_root path -i /
  http-request set-path /xwiki if p_root
so my complete wiki backend now looks like:
backend bk_wiki
   option httpclose
I am trying to do the same process as you for our network, we have a web server + an exchange 2010 server that will sit behind the 1 IP address and using domain names and HAProxy I am trying to get it to forward the domains on.
I can get the webserver working, and I tried to copy your config and setup for our Exchange 2010 but OWA redirects me to /owa but then says 503 Service Unavailable and autodiscovery does not work and phones are not working.
Do you have any suggestion why I would be getting “no server is available to handle this request”.
As well as this config, did you need to do anything to the exchange server?
I needed to reset the the exchange settings to the defaults and set my urls on the exchange server to my external domain (using split dns in my environment).
I used this perfect powershell script to achieve this: https://github.com/cunninghamp/ConfigureExchangeURLs.ps1
Also in my network i needed to set the split dns records so my internal and external users used the same records nomather where they where.
