Haproxy as syslog balancer in docker ignore "init-addr none" settings
Hello
I’d like to balance syslog request via haproxy to syslog containers
I have docker containers - haproxy-service, logger-service, mx-service
Haproxy config
log-forward syslog
    # Accepts incoming TCP messages
    bind *:514
    # Accepts incoming UDP messages
    dgram-bind *:514
    # Forward via udp
    log ring@logbuffer_udp local0
ring logbuffer_udp
    description "udp buffer for logs"
    timeout server 10s
    server logserver logger-service:514 init-addr none
frontend frontend_smtp
    bind *:25
    timeout client 1m
    default_backend backend_smtp
    timeout server 1m
    # Don't change server params in backend. Always need resolver and
    server postfix mx-service:25 send-proxy init-addr none
Haproxy work when i start logger-service first
But if i run haproxy without logger-service i have error
[ALERT] (1) : config : [/etc/haproxy/haproxy.cfg:68] : 'server logbuffer_udp/logserver' : invalid address: 'logger-service' in 'logger-service:514'
Why haproxy ignore “init-addr none” settings in “ring logbuffer_udp” section but accept in “backend backend_smtp” ?
I doubt resolvers are implemented for ring servers, and without resolver support, init-addr none can’t work.
You may want to file a feature request at
