Haproxy Forwoard Original IP ADDRESS
Hi everyone, I’m trying to implement haproxy in my infrastructure - but I have a problem even if I use option forwardfor I don’t see the IP address of the client that made the request appear but only that of haproxy. I also configured haproxy with the log-forward option which collects the network logs and sends them to the syslog server. But even there the logs are written with the IP address of the haproxy and not of the client that generated the log.
My Conf
    log ring@logbuffer local5
    maxconn 256
    timeout connect 5000ms
    timeout client 50000ms
    timeout server 50000ms
log-forward syslog
Accepts incoming TCP messages
bind 192.168.16.46:1514
Accepts incoming UDP messages
dgram-bind 192.168.16.46:1514
Sends outgoing messages via UDP
log ring@logbuffer local0
ring logbuffer
description “buffer for logs”
format rfc5424
maxlen 1500
size 65536
timeout server 20s
Sends outgoing messages via TCP
root@haproxy:/ # cat /usr/local/etc/haproxy.conf
    maxconn 256
log-forward syslog
ring logbuffer
format rfc5424
maxlen 1500
size 65536
timeout server 20s
server logserver 192.168.10.21:1514 check send-proxy
    frontend fe_rsync
            bind 192.168.16.46:873
            use_backend be_rsync
    backend be_rsync
            server rsyncd 192.168.10.9:873  send-proxy-v2
    resolvers mynameservers
            nameserver ns1 192.168.10.5:53
I solved it with rsyncd by activating proxy protocol = true in rsyncd.conf and inserting send-proxy in the backend. I still have to solve syslog-ng I tried with the transport tcp-proxies option but I can’t log in with the original IP address
Thank
I have carried out various tests but the log comes to me with both HOST and HOST_FROM with the IP address of the HAPROXY, I don’t get the source IP address
Did you find a way eventually? Thanks.
