Hello everyone, i am new to HAProxy and struggling for more than 3 days to make it works but unfortunately nothing achieved.
So i short words trying to achieve this kind of logic:
Dedicated Server (Proxmox VE+ 1 Public IP) → (NAT) OPNsense + HAProxy → Other VMs connected to OPNsense LAN interface.
The configuration of Proxmox Server is as the following:
source /etc/network/interfaces.d/*
auto lo
iface lo inet loopback
auto enp0s31f6
iface enp0s31f6 inet static
address 94.130.x.x/26
gateway 94.130..x.x
auto vmbr0
iface vmbr0 inet static
address 10.10.10.1/24
bridge-ports none
bridge-stp off
bridge-fd 0
post-up echo 1 > /proc/sys/net/ipv4/ip_forward
post-up iptables -t nat -A POSTROUTING -s '10.10.10.0/24' -o enp0s31f6 -j MASQUERADE
post-down iptables -t nat -D POSTROUTING -s '10.10.10.0/24' -o enp0s31f6 -j MASQUERADE
post-up iptables -t raw -I PREROUTING -i fwbr+ -j CT --zone 1
post-down iptables -t raw -D PREROUTING -i fwbr+ -j CT --zone 1
auto vmbr1
iface vmbr1 inet static
address 172.16.0.1/24
bridge-ports none
bridge-stp off
bridge-fd 0
Ok, so created new VM(OPNsense), install and configure it as following:
WAN → vtnet0 (bridge to vmbr0 at Proxmox Server)
LAN → vtnet1 (brigde to vmbr1 at Proxmox Server)
WAN configured with 10.10.10.10/24
LAN configured with 172.16.0.1/24 DHCP(yes) Range: 172.16.0.2-172.16.0.254
Now the servers part:
- VM 1
VM(Ubuntu Server) with OpenLiteSpeed Web Server running (example.com) and Postfix/Dovecot for email purposes and connected to vmbr1 (LAN of OPNsense connected to Proxmox vtnet1)
The Ubuntu server get the IP successfully via OPNsense as following → IP 172.16.0.2 , Gateway 172.16.0.1.
- VM2
VM(Ubuntu Server) with OpenLiteSpeed Web Server running (anotherexample.com) and Postfix/Dovecot for email purposes and connected to vmbr1 (LAN of OPNsense connected to Proxmox vtnet1)
The Ubuntu server get the IP successfully via OPNsense as following → IP 172.16.0.3 , Gateway 172.16.0.1.
Both of the VMs connected through OPNsense LAN and able to communicate with public internet successfuly.
OK now the hard part
CloudFlare DNS for example.com:
A Record example.com pointing to Public IP of Proxmox Server -> 94.130.x.x
Created some iptables rules to communicate from Public IP to local OPNsense and HAProxy:
For OPNsense:
iptables -t nat -A PREROUTING -p tcp --dport 10443 -j DNAT --to-destination 10.10.10.10:10443
HAProxy configuration:
uid 80
gid 80
chroot /var/haproxy
stats socket /var/run/haproxy.socket group proxy mode 775 level admin
nbthread 1
hard-stop-after 60s
no strict-limits
spread-checks 2
tune.bufsize 16384
tune.lua.maxmem 0
log /var/run/log local0 info
lua-prepend-path /tmp/haproxy/lua/?.lua
option redispatch -1
timeout client 30s
timeout connect 30s
timeout server 30s
default-server init-addr last,libc
# Frontend: Public_Facing_Pool ()
frontend Public_Facing_Pool
bind *:443 name *:443 proto h2
bind *:80 name *:80 proto h2
maxconn 500
# logging options
# ACL: Web-Server
acl acl_65baf2832edf80.37086579 hdr_beg(host) -i example.com
# ACL: Web-Server1
acl acl_66baf2832edf80.37086579 hdr_beg(host) -i anotherexample.com
# ACTION: Web-Server
use_backend Web-Server if acl_65baf2832edf80.37086579
# ACTION: Web-Server1
use_backend Web-Server1 if acl_66baf2832edf80.37086579
# Backend: Web-Server ()
backend Web-Server
# health checking is DISABLED
http-reuse safe
server Web-Server 172.16.0.2:443
# Backend: Web-Server1 ()
backend Web-Server
http-reuse safe
server Web-Server 172.16.0.3:443
# Backend: acme_challenge_backend (Added by ACME Client plugin)
backend acme_challenge_backend
balance source
# stickiness
stick on src
http-reuse safe
server acme_challenge_host 127.0.0.1:43580
# statistics are DISABLED
Trying to open in browser example.com it fails to open.
Please anybody can help to achieve that since it is very important for me and I don’t know anymore what to do, coming around to this more than 3 days for hours and hours. I don’t know if something wrong with it or lack of my knowledge.
