Afternoon - I have completed a cluster build of 2 x haproxy servers sat on 2 x Ubuntu Servers using Pacemaker / Corosync / Heartbeat. The cluster sits infront of 3 x MS IIS web servers
The resources appear to be configured ok and fail over works well.
I have 2 issues, which I suspect are related. When I call up a web page served by the IIS servers on the local same subnet it will initially take anything up to 9 seconds to load. If I then close the web page and reopen the link it is considerably faster.
The second issue is that if I then try and access the web pages from another subnet, sometimes it will load - slowly, but mostly it times out.
Clearly I have missed something - so in the first instance has anyone else suffered a similar thing?
Below is the base haproxy.cfg:
System information as of Tue Apr 2 15:02:49 UTC 2019
System load: 0.79 Processes: 141
GNU nano 2.9.3 /etc/haproxy/haproxy.cfg
bind *:1936
maxconn 10
clitimeout 100s
srvtimeout 100s
contimeout 100s
timeout queue 100s
stats hide-version
stats refresh 30s
stats show-node
stats auth xxxxx
stats uri /haproxy?stats
frontend http_front
bind 172.21.1.119:80
default_backend http_back
backend http_back
server xxxxxxxxx 172.21.1.169:80 check
server xxxxxxxxx 172.21.1.168:80 check
A tcpdump from a host on another subnet - the requests are inbound but dont sem to be responded to:
sysadmin@haproxy1:~$ sudo tcpdump -i eth0 host 192.168.75.54
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
15:52:40.263804 IP ukbcalt45324.autologic.int.63371 > haproxy.http: Flags [S], seq 2415765373, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
15:52:40.266058 IP ukbcalt45324.autologic.int.63372 > haproxy.http: Flags [S], seq 1828596436, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
15:52:40.513741 IP ukbcalt45324.autologic.int.63373 > haproxy.http: Flags [S], seq 289814379, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
15:52:43.264073 IP ukbcalt45324.autologic.int.63371 > haproxy.http: Flags [S], seq 2415765373, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
15:52:43.266619 IP ukbcalt45324.autologic.int.63372 > haproxy.http: Flags [S], seq 1828596436, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
15:52:43.513608 IP ukbcalt45324.autologic.int.63373 > haproxy.http: Flags [S], seq 289814379, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
15:52:49.264183 IP ukbcalt45324.autologic.int.63371 > haproxy.http: Flags [S], seq 2415765373, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
15:52:49.267135 IP ukbcalt45324.autologic.int.63372 > haproxy.http: Flags [S], seq 1828596436, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
15:52:49.514263 IP ukbcalt45324.autologic.int.63373 > haproxy.http: Flags [S], seq 289814379, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
15:53:01.397340 IP ukbcalt45324.autologic.int.63384 > haproxy.http: Flags [S], seq 1529278499, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
15:53:04.396828 IP ukbcalt45324.autologic.int.63384 > haproxy.http: Flags [S], seq 1529278499, win 64240, options [mss 1460,nop,wscale 8,nop,nop,sackOK], length 0
