Hi HAProxy Community,
I have deployed HAProxy as a load balancer in front of two Bitbucket applications.
Production traffic has recently been diverted to hit HAProxy and I am seeing a worrying downwards trend.
Here is a screenshot of the memory usage, the flatline was during application and migration testing for Bitbucket. The downwards trend in memory starts very shortly after production traffic was routed to the new system:
Increasing the resources on this server is not completely out of the question, but I would prefer to get at the root cause of why so much memory is being used.
This is not an internet facing application so the traffic is relatively low.
Please let me know if this is actually an expected amount of memory usage or if I have misconfigured something to do with how memory is released by the application.
In the documentation I do see mention of the haproxy -m <MB> option but I am unsure if this is a safe release when memory limits are hit, is there any downtime incurred when the application realizes it needs to release a whole bunch of memory?
For additional information I have included the output of a couple of commands.
Results of: haproxy -vv
HA-Proxy version 2.2.4-de45672 2020/09/30 - https://haproxy.org/
Known bugs: http://www.haproxy.org/bugs/bugs-2.2.4.html
Running on: Linux 3.10.0-1160.24.1.el7.x86_64 #1 SMP Thu Apr 8 19:51:47 UTC 2021 x86_64
TARGET = linux-glibc
CC = gcc
CFLAGS = -O2 -g -Wall -Wextra -Wdeclaration-after-statement -fwrapv -Wno-unused-label -Wno-sign-compare -Wno-unused-parameter -Wno-clobbered -Wno-missing-field-initializers -Wtype-limits
OPTIONS = USE_PCRE=1 USE_PCRE_JIT=1 USE_THREAD=1 USE_LINUX_TPROXY=1 USE_OPENSSL=1 USE_ZLIB=1 USE_TFO=1 USE_NS=1 USE_SYSTEMD=1
Feature list : +EPOLL -KQUEUE +NETFILTER +PCRE +PCRE_JIT -PCRE2 -PCRE2_JIT +POLL -PRIVATE_CACHE +THREAD -PTHREAD_PSHARED +BACKTRACE -STATIC_PCRE -STATIC_PCRE2 +TPROXY +LINUX_TPROXY +LINUX_SPLICE +LIBCRYPT +CRYPT_H +GETADDRINFO +OPENSSL -LUA +FUTEX +ACCEPT4 +ZLIB -SLZ +CPU_AFFINITY +TFO +NS +DL +RT -DEVICEATLAS -51DEGREES -WURFL +SYSTEMD -OBSOLETE_LINKER +PRCTL +THREAD_DUMP -EVPORTS
Built with gcc compiler version 4.8.5 20150623 (Red Hat 4.8.5-39)
<default> : mode=HTTP side=FE|BE mux=H1
<default> : mode=TCP side=FE|BE mux=PASS
Available services : none
[FCGI] fcgi-app
Results of: show pools
Dumping pools usage. Use SIGQUIT to flush them.
- Pool comp_state (32 bytes) : 51 allocated (1632 bytes), 48 used, needed_avg 41, 0 failures, 6 users, @0x556b4c5b0b00=09 [SHARED]
- Pool filter (64 bytes) : 1682237 allocated (107663168 bytes), 1682237 used, needed_avg 1682232, 0 failures, 9 users, @0x556b4c5b0a80=08 [SHARED]
- Pool pendconn (96 bytes) : 0 allocated (0 bytes), 0 used, needed_avg 0, 0 failures, 4 users, @0x556b4c5b0b80=10 [SHARED]
- Pool ssl_sock_ct (128 bytes) : 209 allocated (26752 bytes), 86 used, needed_avg 168, 0 failures, 3 users, @0x556b4c5b0680=00 [SHARED]
- Pool h1c (160 bytes) : 206 allocated (32960 bytes), 101 used, needed_avg 165, 0 failures, 4 users, @0x556b4c5b0800=03 [SHARED]
- Pool fcgi_strm (192 bytes) : 177 allocated (33984 bytes), 85 used, needed_avg 142, 0 failures, 5 users, @0x556b4c5b0700=01 [SHARED]
- Pool tcpcheck_ru (224 bytes) : 74 allocated (16576 bytes), 73 used, needed_avg 63, 0 failures, 3 users, @0x556b4c5b0980=06 [SHARED]
- Pool authority (256 bytes) : 2 allocated (512 bytes), 1 used, needed_avg 0, 0 failures, 2 users, @0x556b4c5b0d00=13 [SHARED]
- Pool spoe_ctx (320 bytes) : 0 allocated (0 bytes), 0 used, needed_avg 0, 0 failures, 1 users, @0x556b4c5b0a00=07 [SHARED]
- Pool dns_resolut (480 bytes) : 0 allocated (0 bytes), 0 used, needed_avg 0, 0 failures, 1 users, @0x556b4c5b0c00=11 [SHARED]
- Pool dns_answer_ (576 bytes) : 0 allocated (0 bytes), 0 used, needed_avg 0, 0 failures, 1 users, @0x556b4c5b0c80=12 [SHARED]
- Pool requri (1024 bytes) : 0 allocated (0 bytes), 0 used, needed_avg 0, 0 failures, 1 users, @0x556b4c5b0e00=15 [SHARED]
- Pool stream (1088 bytes) : 105 allocated (114240 bytes), 29 used, needed_avg 93, 0 failures, 1 users, @0x556b4c5b0900=05 [SHARED]
- Pool fcgi_conn (1216 bytes) : 0 allocated (0 bytes), 0 used, needed_avg 0, 0 failures, 1 users, @0x556b4c5b0780=02 [SHARED]
- Pool h2c (1312 bytes) : 11 allocated (14432 bytes), 8 used, needed_avg 10, 0 failures, 1 users, @0x556b4c5b0880=04 [SHARED]
- Pool hpack_tbl (4096 bytes) : 11 allocated (45056 bytes), 8 used, needed_avg 10, 0 failures, 1 users, @0x556b4c5b0f00=17 [SHARED]
- Pool buffer (16384 bytes) : 66 allocated (1081344 bytes), 46 used, needed_avg 60, 0 failures, 1 users, @0x556b4c5b0e80=16 [SHARED]
- Pool trash (16416 bytes) : 2 allocated (32832 bytes), 2 used, needed_avg 0, 0 failures, 1 users, @0x556b4c5b0f80=18
Total: 18 pools, 109063488 bytes allocated, 108586112 used.
Haproxy config
maxconn 4000
stats socket REDACTED mode 600 level admin
log REDACTED
chroot REDACTED
pidfile REDACTED
ssl-default-bind-ciphers REDACTED
ssl-default-bind-options REDACTED
ssl-default-server-ciphers REDACTED
ssl-default-server-options REDACTED
ssl-dh-param-file REDACTED
timeout http-request 10s
timeout queue 1m
timeout client 1m
timeout server 1m
timeout http-keep-alive 10s
timeout check 10s
maxconn 3000
errorfile 408 /dev/null # Workaround for Chrome 35-36 bug. See http://blog.haproxy.com/2014/05/26/haproxy-and-http-errors-408-in-chrome/
frontend bitbucket_frontend_http
bind *:REDACTED
bind *:REDACTED ssl crt REDACTED
default_backend bitbucket_backend_http
option httpchk GET /status
cookie BITBUCKETSESSIONID prefix
stick-table type string len 52 size 5M expire 30m
stick store-response set-cookie(BITBUCKETSESSIONID)
stick on cookie(BITBUCKETSESSIONID)
server REDACTED check inter 10000 rise 2 fall 5
frontend bitbucket_frontend_ssh
bind *:REDACTED
default_backend bitbucket_backend_ssh
timeout client 15m
maxconn 50
server REDACTED check port REDACTED
timeout server 15m
listen admin
bind *:REDACTED
stats auth REDACTED
stats uri REDACTED
