THIS IS WHAT I NEED TO ACCOMPLISH…
On DDC_HA_PROXY_SERVER I want to have ddcnode1 and ddcnode2 in a roundrobin while having ftwnode1 as a backup. ONLY If ddcnode1 and ddcnode2 are down, then traffic will forward to ftwnode1.
On FTW_HA_PROXY_SERVER I want ftwnode1 to be the primary, with traffic forwarding to ddcnode1 and ddcnode2 (roundrobin), ONLY if ftwnode1 goes down.
DDC_HA_PROXY_SERVER
*bind :9999
stats hide-version
stats uri /stats
stats auth admin:admin
frontend webserver
*bind :80
default_backend appserver
backend appserver
balance uri
hash-type consistent
server ddcnode1 172.16.5.30:80 check observe layer7 maxconn 5000 id 1 weight 75
server ddcnode2 172.16.5.31:80 check observe layer7 maxconn 5000 id 2 weight 75
server ftwnode1 10.2.3.200:80 check observe layer7 maxconn 5000 id 3 weight 25
________________________________________________________________________________
FTW_HA_PROXY_SERVER
*bind :9999
stats hide-version
stats uri /stats
frontend webserver
*bind :80
backend appserver
balance uri
server ftwnode1 10.2.3.200:80 check observe layer7 maxconn 5000 id 3 weight 100
server ddcnode1 172.16.5.30:80 check observe layer7 maxconn 5000 id 1 weight 25
server ddcnode2 172.16.5.31:80 check observe layer7 maxconn 5000 id 2 weight 25
Drop the weight keyword and use backup directive instead.
Like this?
DDC_HA_PROXY_SERVER
server ftwnode1 10.2.3.200:80 check observe layer7 maxconn 5000 id 3 backup 100
FTW_HA_PROXY_SERVER
server ddcnode1 172.16.5.30:80 check observe layer7 maxconn 5000 id 1 backup 50
server ddcnode2 172.16.5.31:80 check observe layer7 maxconn 5000 id 2 backup 50
Yes, but there is no point in declaring the weight. Remove the weight from all servers.
so should i leave it as balance uri? or do i change it to roundrobin?
Whatever you like.
You have written you want to do roundrobin between the primary servers though so I don’t see why you would use balance uri?
Right, switched to RR on both servers.
on this one, there is no load balancing going on between the backup servers.
Should i instead, add the other server as the backup instead of the nodes? Would that allow traffic to pass to the server and be distributed appropriately?
FTW_HA_PROXY_SERVER
server ddchaproxyserver 172.16.5.32:80 check observe layer7 maxconn 5000 id 4 backup
//server ddcnode1 172.16.5.30:80 check observe layer7 maxconn 5000 id 1 backup
//server ddcnode2 172.16.5.31:80 check observe layer7 maxconn 5000 id 2 backup
Yes, by default, only the first backup server is used, as per the documentation I linked above:
By default, only the first operational backup server is used, unless the “allbackups” option is set in the backend.
Is that what you mean? Because I’m not sure I understood your question, specifically I don’t understand the difference between servers and nodes.
When I refer to nodes, its just the appserver on the front end. I would like to use the “allbackups” function. would I use that instead of just “backup”? I’ve been looking everywhere for a more comprehensive guide to haproxy, but a lot of what I’ve seen is default configurations. even in the documentation, I don’t remember any material on backup servers.
option allbackup is an option (an additional configuration directive), that needs to be set in either in the default or the backend section, as per the documentation (May be used in sections).
The server configuration lines with the backup keyword remains as-is.
