If i manually do “service haproxy restart” it’s working again.
haproxy -vv
HA-Proxy version 1.8.8-1ubuntu0.3 2019/01/11
TARGET = linux2628
CC = gcc
CFLAGS = -g -O2 -fdebug-prefix-map=/build/haproxy-_XfIfg/haproxy-1.8.8=. -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2
OPTIONS = USE_GETADDRINFO=1 USE_ZLIB=1 USE_REGPARM=1 USE_OPENSSL=1 USE_LUA=1 USE_SYSTEMD=1 USE_PCRE=1 USE_PCRE_JIT=1 USE_NS=1
Built with OpenSSL version : OpenSSL 1.1.0g 2 Nov 2017
Running on OpenSSL version : OpenSSL 1.1.0g 2 Nov 2017
I think I’d try putting in a valid resolvers section, it maybe shouldn’t need it as it’s fine when you start the service but it’s clearly trying and failing to lookup on the restart.
The other option is switch to using an IP address for SMTP mailer and see if the problem persists, i have a feeling it wont…
cat /lib/systemd/system/haproxy.service
[Unit]
Documentation=man:haproxy(1)
Documentation=file:/usr/share/doc/haproxy/configuration.txt.gz
After=network.target rsyslog.service
[Service]
EnvironmentFile=-/etc/default/haproxy
Environment="CONFIG=/etc/haproxy/haproxy.cfg" "PIDFILE=/run/haproxy.pid"
ExecStartPre=/usr/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS
ExecStart=/usr/sbin/haproxy -Ws -f $CONFIG -p $PIDFILE $EXTRAOPTS
ExecReload=/usr/sbin/haproxy -f $CONFIG -c -q $EXTRAOPTS
KillMode=mixed
Restart=always
Type=notify
# The following lines leverage SystemD's sandboxing options to provide
# defense in depth protection at the expense of restricting some flexibility
# in your setup (e.g. placement of your configuration files) or possibly
# reduced performance. See systemd.service(5) and systemd.exec(5) for further
# information.
# NoNewPrivileges=true
# ProtectHome=true
# If you want to use 'ProtectSystem=strict' you should whitelist the PIDFILE,
# any state files and any other files written using 'ReadWritePaths' or
# 'RuntimeDirectory'.
# ProtectSystem=true
# ProtectKernelTunables=true
# ProtectKernelModules=true
# ProtectControlGroups=true
# If your SystemD version supports them, you can add: @reboot, @swap, @sync
# SystemCallFilter=~@cpu-emulation @keyring @module @obsolete @raw-io
[Install]
WantedBy=multi-user.target
