Here is examples for nginx and apache, but I need for haproxy
https://helpcenter.onlyoffice.com/server/document/document-server-proxy.aspx
My haproxy.cfg
maxconn 16384
log 127.0.0.1 local1 debug
stats socket /var/run/haproxy_info.sock mode 666 level user
stats timeout 2m
maxconn 16384
timeout client 5s
timeout queue 5s
timeout server 30s
timeout tunnel 1h
frontend cloud
acl is_oo path_beg /oo
option forwardfor header X-Real-IP
use_backend ooffice if is_oo
default_backend cloudnodes
backend cloudnodes
server own-01 1.2.3.40:80 check cookie own-01 check inter 1000 rise 1 fall 1
server own-02 1.2.3.41:80 check cookie own-02 check inter 1000 rise 1 fall 1
backend ooffice
option httpclose
http-request add-header X-Forwarded-For %[src]
http-request set-header X-Client-IP %[src]
http-request set-header X-Forwarded-Proto http
http-request set-header Forwarded proto=http
http-request add-header Host %[src]
http-request add-header X-Forwarded-Host %[src]
http-request add-header X-Forwarded-Server %[src]
reqrep ^([^\ :])\ /oo(.) \1\ \2
server oo-01 1.2.3.4:80
