Hi community,
I’m trying to build an HAProxy setup to make available some LAN Servers from external. The majority is HTTP/HTTPS ports to forward but I also have some TCP ports to forward
I have this basic setup in place and working:
HAProxy server is in my DMZ, I have a firewall between WAN <-> DMZ and DMZ <-> LAN. Servers are in LAN.
The goal here is to go further and enhance my configuration as well as fix bugs I have. Currently all HTTPS redirects are working fine, but not TCP. I also have a problem to identify my sources correctly. For example, if I have two different source to redirect on the two different backend but on same port (this is the case with 8443, I need to add a new backend on 8443), I’m not able to make the difference between them and redirect them on the good backend.
Servers and ports that need to be accessed from outside:
- ITAM1 TCP: 8027 HTTPS: 8383 8022 8020 8021 8443 8444 8031
- ITAM2 HTTPS: 8443
- ITSM TCP: 9000 HTTPS: 443
- AV TCP: 8013 8014
- OTHER HTTPS: 8085 9443
My configuration file, looks like this so far. This is my first use at HAProxy and the conf I have done is really basic. Please be indulgent!
maxconn 4096
#ca-base /etc/ssl/certs
# tune & ssl params to force diffie-hellman defaults, disallow most tls/poodle attacks, and restrict binders to secure ciphers
#tune.ssl.default-dh-param 4096
#ssl-default-bind-options no-sslv3 no-tls-tickets
#ssl-default-bind-ciphers EECDH+AESGCM:EDH+AESGCM:AES256+EECDH:AES256+EDH:EECDH+AES
log 127.0.0.1 local0 notice
frontend tcpServers
bind *:8013
bind *:8014
bind *:8027
bind *:8383
bind *:8022
bind *:8020
bind *:8021
bind *:8443
bind *:8444
bind *:8031
bind *:443
bind *:9000
bind *:8085
bind *:9443
#bind *:443 ssl crt /etc/haproxy/certs/ no-sslv3
#ACL by Port
acl tcp_8013 dst_port 8013
acl tcp_8014 dst_port 8014
acl tcp_8027 dst_port 8027
acl https_8383 dst_port 8383
acl http_8022 dst_port 8022
acl https_8020 dst_port 8020
acl https_8021 dst_port 8021
acl https_8443 dst_port 8443
acl https_8444 dst_port 8444
acl https_8031 dst_port 8031
acl https_443 dst_port 443
acl tcp_9000 dst_port 9000
acl http_8085 dst_port 8085
acl https_9443 dst_port 9443
# Start SSL Passthrough Backend #
backend fortiemstcp8013
server fortiems X.X.X.X:8013
backend fortiemstcp8014
server fortiems X.X.X.X:8014
backend itamtcp8027
server itam X.X.X.X:8027
backend itamhttps8383
server itam X.X.X.X:8383
backend itamhttp8022
server itam X.X.X.X:8022
backend itamhttps8020
server itam X.X.X.X:8020
backend itamhttps8021
server itam X.X.X.X:8021
backend itamhttps8443
server itam X.X.X.X:8443
backend itamhttps8444
server itam X.X.X.X:8444
backend itamhttps8031
server itam X.X.X.X:8031
backend supportcenterhttps443
server supportcenter X.X.X.X:443
backend supportcentertcp9000
server supportcenter X.X.X.X:9000
backend assetshttp8085
server assets X.X.X.X:8085
backend assetshttps9443
server assets X.X.X.X:9443
